Old 10-07-2024, 08:36 PM   #1
vividpixel   vividpixel is offline
vividpixel's Avatar
Rear brake caliper bolt identification (Templar X)
My rear brake caliper has one bolt that is way too tight from factory, and it's now stripped. The head of it is a 4mm set screw and only that portion is threaded. What do you call this style of bolt? A ton of bonus points if you know where to get one, but I'd settle for knowing what to look for.
A replacement caliper may be easier than extraction and would be my fallback plan. I see the entire rear caliper on Zuumav's parts diagram under Handlebar Assembly, but I cannot find anything matching their part number for it: 06.08.0580
Their AliExpress store doesn't even show results if you search for the word "caliper."
Templar X 250, current config: 13t/45t, X-ring, PE30, K772 DT
Old 10-07-2024, 09:51 PM   #2
Bruces   Bruces is offline
That’s a calliper pin ,or a calliper slide pin ,you can get them at any auto parts store ,but probably not for your china bike .
Old 10-07-2024, 11:40 PM   #3
vividpixel's Avatar
It seems Harley Davidson Sportster models use the same design. I assume this would be far larger than what I need: https://a.co/d/ghInHnI ("Harddrive Caliper Pad Pins - Rear")
Found a couple options for Can-Am Mavericks or Commanders, which I'm sure are also too big.
I will try to get in touch with Zuumav and see if they'll sell the slide pins or a caliper. Good time to ask about a rear brake pedal, too, since that's another thing I haven't found a replacement for. China bikes are definitely inconvenient sometimes, but it beats not riding at all, or going into debt to do so.
Old 10-08-2024, 07:48 AM   #4
CC-John   CC-John is online now
CC-John's Avatar
The Templar X brake calipers are a clone of the 1985-1987 Honda CMX250C Rebel front brake caliper. Might be worth taking a chance to see if OEM Honda parts fit..
Here's a link to a parts breakdown on Partszilla..
https://www.partzilla.com/catalog/ho...s9-BDTx2MqMa8B
The EBC FA-86 brake pads that fit these bikes also fit a few Kymco models.. Might be worth looking for caliper parts for these.
Active SR 50 • 2008
Nexxon 125 E3 2008
Nexxon 50 2008
Hope this helps..
CC-John
"I void warranties"
2024 Templar 250 X
2018 Nissan Frontier (work truck)
2006 Ford F-150 Crew cab (play truck)
1973 Century Resorter 16 (Floating Muscle Car)
Old 10-08-2024, 09:27 AM   #5
GypsyR   GypsyR is offline
GypsyR's Avatar
Is it in these diagrams? Kind of small and hard to see. https://www.chinariders.net/showthread.php?t=34693
2023 Templar 250 X
Old 10-09-2024, 12:32 PM   #6
vividpixel's Avatar
That's the diagram I referenced at the end of my post, and it does have the alleged part number for the rear caliper, but even that number seems entirely useless.
Originally Posted by CC-John View Post
Hope this helps..
It might! I emailed Zuumav on Sunday night (info at zuumavmoto dotcom) but no reply yet, not even an auto-response. Not too hopeful on that.
There's a bright side, which is that my rear brake pads have plenty of life left, so in the meantime it's ride-able. Which is great, because with the weather finally cooling down to less than 100 degrees, and a very fresh separation from my partner, I may be wanting to ride often.
