Old 09-21-2024, 07:54 PM   #526
XLsior   XLsior is online now
XLsior's Avatar
Edit 42P 135M was the winter tune.
I have installed 38P 138M jets. still 4th needle clip.
Old 10-03-2024, 09:33 PM   #527
XLsior's Avatar
Might be the nail in the coffin for the this CG250...
Old 10-03-2024, 09:56 PM   #528
XLsior's Avatar
Engine swaping alternatives
So the OG $80aud basket case used CG seems to be on the way out...
The blown headgasket ordeal might have been to much for it and it's giving up.
Oil is sweating out of it and the clacky bottom end is knocking on heavens door.
So I have some options...I while back I picked up a few used chonda engines after my catastrophic head gasket fail...
I used some parts of a Dukar CG250 to save the OG engine...So I have the option of using the Dukar core and bottom end and swapping parts over from the OG....However the Dukar looks about as abused so its a toss up how long that will hold up...
I also have some smaller displament 200cc CB/CG chondas...unknown quality.
And finally the gem being the 169FMM CB250 that appears newish* and I got to turn over after finding all that was wrong was a stuck intake valve...The issue being the valve/cam cover fouls on my modified XL350 fuel tank...
But it might be possible to dent some clearance...
Not what I had planned for the weekend as I am now in a position where all my vehicles are pit stopped for some reason.
I will try the 169FMM first...
ID:	32045   Click image for larger version
Old 10-04-2024, 04:25 PM   #529
XLsior's Avatar
CB250 and tank fit check
Got the 81 frame out for a test fit before committing to installing the CB250 into the 92 frame.
Would appear to fit no issue but looking under the tank the CDI and inner tank wall are likely kissing, but its close enough that I'm ok shaving 1 side or love tapping the other to call it doable.
With that information I proceeded to rip out the tired old heart 'again' and bolt in the 169FMM
Got it in before sun down.
ID:	32051   Click image for larger version
ID:	32052   Click image for larger version
Old 10-04-2024, 08:40 PM   #530
XLsior's Avatar
169MM runs but also issues
So I got the 169FMM running...
Good news is that it runs and all gears work...
Bad news is that the clutch is stuck and there is significant blow by...
So its seen some action.
It hot starts pretty well so I'd say the compression is fair and the blowby might improve with more use as I suspect the cylinder and rings might be rough from neglect/sitting.
However Is it worth investing more time and effort into?
I am inclined to use the Dukar CG250 core and swap all the bits over from the busted bigend CG250 OG...
Sorry for thumb in vid shot...Honestly all the gears shift and there is neutral...
Old 10-04-2024, 10:01 PM   #531
XLsior's Avatar
Comparing Rods
So now I had to establish if indeed the bottom end was bad...
after removing the top end on the clacker and comparing it to the Ducar...
I came to the conclusion that they are about the same...
Nothing jumped out suggesting the crank or rod was bad...
So with that piece of insight I have elected to keep running the OG.
Seeing as I went this far I opted to install the 70mm DYNOP flat top piston and send it...
it's just gotta last 6 months of small errand work...and maybe a 700km return trip at Christmas.
Then it can keep leaking oil and collect dust under the house...
The 169FMM will likely go into the 81 frame. As i would have to modify the tank and header pipe to make it fit in the 92 road bike.
ID:	32054   Click image for larger version
Old 10-07-2024, 07:31 AM   #532
XLsior's Avatar
Delving deeper
Pulled of the flywheel cover to see if there was any signs of contact wear or loose items...all looked ok.
rocking the flywheel by hand the clack felt like it might be coming from the other side...
So off came the clutch cover. things looked clean but feeling around there was noticeable slop in the clutch basket...
I took the clutch cover of the Ducar parts engine to cross reference...
And well this is what happened
Old 10-07-2024, 07:40 AM   #533
XLsior's Avatar
Some More upgrades while at it...
While I had the top end deconstructed, Seemed like a last hoorah upgrade opportunity with some parts I had...
New valves and springs.
and grinding a little more clearance on the flat top piston seeing as I had shaved the head and was using a metal head gasket.
Also discovered the AN fitting I had used to shorten the oil cooler lines had failed, So potential major oil leak remedied with a spare long cooler pipe...
ID:	32064   Click image for larger version
ID:	32065   Click image for larger version
ID:	32066   Click image for larger version
Old 10-07-2024, 07:54 AM   #534
XLsior's Avatar
Comparinng Baskets and slingers
So the Zongshen turns out to be a 7 plate clutch with a small oil filter slinger. The basket is shot.
the Ducar has a 6plate clutch with a large slinger.
I have installed the 6 plate clutch and larger oil slinger into the Zongshen engine without issue, All the gasket kits I have only support the larger slinger.
I do not want to spend money on a new 7 plate clutch basket.
Cleaning the Ducar clutch cover to install as it fits on the case no problem but is required to engage with te 6 plate and clear the larger oil slinger...
So the take away is, not all CG250 engines use the same clutch and slinger configuration.
But the friction disks are the same so no harm in buying 7 if you're unsure.
Though if your clutch cover has a bulge around the slinger its likely a 6 plate.
Fingers crossed this sorts out the clacky clacky pop pops
ID:	32068   Click image for larger version
ID:	32069   Click image for larger version
ID:	32070   Click image for larger version
Old 10-07-2024, 11:04 PM   #535
XLsior's Avatar
Shuffling Clutches
After installing the 6plate I got curious and decided to crack open the 169FMM and the 2 remaining Loncin 200cc CG/CB engines...
The 2 loncins have different clutch baskets and less plates...(incompatible)
But it turns out the CB250 has a ZS 7plate and small slinger...In excellent condition albeit some sticky disks
Well I decided to uninstall the 6plate from the CG250 and install the 7plate and put the 6plate in the CB250. /swaparoo
I also found that the clutch covers worked and cleared plate/slinger configuration. So I could keep covers factory original.
I believe both the CG and CB 250s now have working clutches.
the Ducar is now just a parts holder...
However for whatever reason now my clutch cable is too long... So looks like the wallet is getting stung anyway.
Still after 2 days of grime I feel like there's 2 decent running engines...
Well hopefully the clack clack is gone with the sloppy basket binned...I cant think of anything else that might cause it beyond splitting the case...
Old Yesterday, 01:08 AM   #536
XLsior's Avatar
Welp...put it all back together and hit the button...
clacky clacky still...
Through the process of elimination I can only assume its the cam that's dusted and the followers are making harsh contact as the noise is not coming from the valve cover...
Another day of faffery...
Will get it sorted out at some point...Least everything else seems to be updated...
