Yesterday, 08:36 PM | #1 |
Rear brake caliper bolt identification (Templar X)
My rear brake caliper has one bolt that is way too tight from factory, and it's now stripped. The head of it is a 4mm set screw and only that portion is threaded. What do you call this style of bolt? A ton of bonus points if you know where to get one, but I'd settle for knowing what to look for.
A replacement caliper may be easier than extraction and would be my fallback plan. I see the entire rear caliper on Zuumav's parts diagram under Handlebar Assembly, but I cannot find anything matching their part number for it: 06.08.0580 Their AliExpress store doesn't even show results if you search for the word "caliper."
Templar X 250: 14t / 42t, Nibbi PE30 |
Yesterday, 11:40 PM | #3 |
It seems Harley Davidson Sportster models use the same design. I assume this would be far larger than what I need: https://a.co/d/ghInHnI ("Harddrive Caliper Pad Pins - Rear")
Found a couple options for Can-Am Mavericks or Commanders, which I'm sure are also too big. I will try to get in touch with Zuumav and see if they'll sell the slide pins or a caliper. Good time to ask about a rear brake pedal, too, since that's another thing I haven't found a replacement for. China bikes are definitely inconvenient sometimes, but it beats not riding at all, or going into debt to do so.
