Old 08-09-2024, 10:23 PM   #16
Rule6   Rule6 is offline
The Yamaha TTR 230 and Honda CRF 230 both have a similar shape to the link on the KPX. So far I have not found any measurements for those links yet. If anyone knows, just post it here.
Old 08-10-2024, 06:23 AM   #17
Originally Posted by Rule6 View Post
Attachment 31788
Now to search the web for a lowering link that will work.
Very good. Now we're talkin.
Real specs. You have just broken new ground!
Old 08-10-2024, 08:56 AM   #18
Thanks Thumper! When I checked with Kouba Links, he of course never heard of a KPX 250, and did not appear eager to learn about them. It would be great if Lifan were to produce a link. Cheers!
Old 08-10-2024, 09:07 AM   #19
Photo of the link in place on the bike
The link in place...
Name:	KPX250 lower link on bike.jpg
Old 09-20-2024, 09:04 AM   #20
Does anyone out there have a Yamaha TTR 230 or Honda CRF 230? If so, would there be any chance that you could measure the lower link at the bottom end of the rear shock? So far I have not found any measurements online, and I would rather not purchase one just to measure it. Thanks to all involved in Chinariders.net! Lots of great info here.
Old 09-26-2024, 08:05 PM   #21
mark hall   mark hall is offline
I did. 32" seat height is possible with Stock wheels/tires if you drill another hole in the shock AND Add an inch to the bottom link. The bottom link on the KPX250 is mild steel.. so just cut it and weld in some new 1/4" steel. Welds like a dream with MIG. If a Really nice 34" height is acceptable with stock wheels/tires, leave the shock in the stock hole and just add the inch. That's where I ended up, ample travel.. turn in with street tires is AWESOME! Also you can lower the front 2 full inches if you get a handle bar set back kit and diddle the triple clamp. The USD forks have a full 2" of adjustment lower. I may see if I can nab another inch lower with internal mods.. That w/the real super moto 17" wheels should be ideal. Use the stock KPX hubs, but get 17" Hoops/rims ($275 Ebay) that take 8 gauge/4mm thick spokes and buy the spokes to lenghth ($100 2 wks ship). Pretty easy to respoke the stock hubs for 17" hoops. I'd like to compare mine to a KLX300 SM at over twice the price if anybody has one near annapolis MD?
Old 09-26-2024, 08:15 PM   #22
I have pics of my mods to the lower bracket and drilling the lower link. I would like to add a KPX250 Super Moto Conversion forum if possible? Maybe under Jerry's awesome content somewhere?
Old 09-28-2024, 07:29 PM   #23
Koubla and adjustable screw bearing end assemblies probably won't work right depending on how the bearings work when bolts torqued. The stock design is actually pretty sophisticated with sealed roller bearings at every joint.. IMO far easier to just weld in an extra inch between the two holes. Best to check the clearance through out whatever travel you end up with before you weld it up. The whole rear suspension assembly MIG welds beautifully.. it's cast Steel, not cast iron. Pics of mine coming..
Old 10-07-2024, 07:27 PM   #24
Nice work!
Sorry it has taken so long to get back on here, We just got power back last night.
I am very glad to hear that you were successful in lowering the bike. My wife is getting comfortable riding on the road, though it does bring her some challenges. She is eager to do some off-road riding, but I would rather lower her bike first.
Thank you for doing the work and posting it here! Maybe I will buy a new stock link and do the surgery on it.
Old 10-07-2024, 07:31 PM   #25
Looking forward to it
True about the Koubla links. I was hoping I could find one that was close enough to modify. Your solution is very much to be considered. Looking forward to seeing the photos!
kpx 250, kpx250, lowering link
