Old 08-16-2022, 06:57 AM   #31
Falkon45's Avatar
Send venom the picture of your sprocket. They offer great service and reasonable prices... But they are known to lie in their descriptions.
Old 08-16-2022, 11:01 AM   #32
Teklock   Teklock is offline
I'll be the first to tell you I don't know a whole lot about gearing but going from 13T to 17T in the front seems like a lot for any motorcycle. Are you sure that will even fit?
Old 08-16-2022, 11:04 AM   #33
If you have a 13 tooth on the front it's probably because your bike uses a 520 or 530 chain and not a 428. You might want to verify that before ordering a sprocket.
Old 11-23-2022, 09:01 AM   #34
teetswes@gmail.com   teetswes@gmail.com is offline
New Xpro x24 Weird noise when idle only please help me!!!
https://youtube.com/shorts/poVk15rYK9g?feature=share
Old 11-25-2022, 04:43 PM   #35
X-Pro32   X-Pro32 is offline
Bike won’t fire up
Hello All,
My bike BD250-6 will turn on, but don’t turn over. It cranks up, replaced the battery, and the spark plug but no luck. Any ideas?
Old 05-03-2023, 10:18 PM   #36
Dddogg11   Dddogg11 is offline
Hey Guzman I have the X24 and I've been looking for gears too and so far the closest I've found that should work are for a KTM RC250 or 250RC I forget what it's actually called but check them out on Amazon, there pretty cheap too
Old 05-30-2023, 11:05 PM   #37
Nines   Nines is offline
I just bought a 2023 Roadster 250 and want to totally debadge it. Remove all stripes etc. All of the stripes and badging seams to be sealed with the clear coat. Any suggestions on how to remove them without messing up the paint and clearcoat?
Old 09-04-2023, 08:25 PM   #38
Woodvr15   Woodvr15 is offline
Chain and sprocket?
I have the BD250-5 (x-pro efi roadster 250cc) and they don't include the 17 T sprocket in the purchase and I want to increase to end speed so I can use our freeways just a little it's OK if I lose acceleration but I'm not sure what chain size and sprocket size I go with on the rear. From above I've learned I need the D.I.D. X-ring 428vx chain so then do I buy a 428 17T front sprocket and 428 38T rear sprocket? I know this is a year old post but I'm looking for answers and can't find this info.
Old 10-05-2024, 11:12 PM   #39
ktwalker   ktwalker is offline
X-pro BD250-5 EFI
Hi Folks,
I have a BD250-5 motorcycle. The fluid light has come on in the console panel. The manual does not explain what it means and how to fix it. The light came on about a week after an oil change. I double checked, and the oil level is fine.
Any advice? In my area, no motorcycle repair people will look at it or give advice.
Best regards,
Kris
xpro 250cc efi
