Old 09-12-2024, 02:45 AM   #16
danklyrides   danklyrides is online now
Update at 850 miles
I've been on some long trips on my other bikes so haven't ridden the Tank a ton recently. I've tracked fuel mileage for 7 fill-ups so far and my average is 68.4 mpg, best so far is 72.1 mpg.
I installed some small LED visibility lights on the front fork shields. Here are some of the install pics.
I will post some pics of the final result later
Cheers!
Dankly
ID:	31934   Click image for larger version
ID:	31935   Click image for larger version
ID:	31936   Click image for larger version
ID:	31937   Click image for larger version
Old 09-24-2024, 04:02 PM   #17
AndoSama   AndoSama is offline
Hello, I am also a new owner of a tank. Can you tell me what you're getting for max speed? I feel as though mine is a bit underpowered compared to the old falcon 200 it is replacing (they have same engine, just tank has efi)
Old 09-24-2024, 08:57 PM   #18
On a flat road with the boxes mounted but no cargo I can get 53 mph. 54 if I go into a bit of a tuck to cut wind resistance.
I'm also not very pleased with that. I've been hoping that things would loosen up a bit and it would get a little faster with miles...but I just hit 1000 miles today, and no luck.
Old 09-24-2024, 11:12 PM   #19
Here are the pics I promised of my front fork lights installed and working. Next, I really need to do something about the front turn signals. They are really bad!
ID:	32010   Click image for larger version
Old 10-02-2024, 09:11 PM   #20
I fixed my wimpy turn signal issue. Got this set from Amazon:
LED Turn Signals
I mounted the fronts in the stock location using reflector brackets that I took off of my KLX 300. To keep the wiring clean I soldered the original connectors onto the new lights.
For the rears, I again used the original mounting spots but I used butt connectors with built in heat shrink because all the wires hide behind the license plate light.
I now have white running lights (instead of red) in the front and still have red ones in the rear. Both front and back have sequential amber lights when in turn signal mode. All of the lights are much brighter than the stock ones.
ID:	32037   Click image for larger version
ID:	32038   Click image for larger version
ID:	32039   Click image for larger version
ID:	32040   Click image for larger version
200 efi, tank, vitacci
