Old 09-29-2024, 12:30 AM   #1
NateTt250   NateTt250 is offline
2020 csc tt250
Where do these lines connect to? I think a few of them are mixed up but I can’t find a proper diagram for them or anything in videos. My bike isn’t starting at all and I’m not sure if this is the cause
ID:	32023   Click image for larger version
Old 09-29-2024, 07:00 AM   #2
Looks like a vacuum line for you EGR valve. Not necessary, at least won't keep it from running. But if the vacuum source that plugs into is not plugged, it could make it hard to start.
No matter where you go, there you are
Old 09-29-2024, 04:35 PM   #3
I’m pretty new to this and have no idea where they should be connected to
Old 09-30-2024, 12:50 PM   #4
superjocko   superjocko is offline
The hose in your first photo is supposed to attach to a fitting on the intake manifold. The intake manifold is the black rubber piece between the cylinder head and the carburetor.
The fitting on the side of the carburetor is the float bowl vent. If the bike is equipped with an evaporative emissions canister, it connects to one of the fittings on the canister. The canister is a round black piece about the size of a regular can of soup and would be located under the left side fairing. The other fitting on the canister is for the fuel tank vent hose. If your bike is no longer equipped with a canister (someone removed it), you can simply connect a length of hose to that fitting on the carburetor and route it down under the bike, alongside the hose that comes off the bottom of the carburetor, which is the float bowl drain hose.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come.
Old 09-30-2024, 12:54 PM   #5
It's a pulsed air injection valve, not an EGR (exhaust gas recirculation) valve.
Old 09-30-2024, 04:09 PM   #6
CheapThrills   CheapThrills is offline
Never understood why the low temp hoses and everyone calls them EGR valves too.
3 lines I found on my bike, 1 sensing line(being held), a line to draw filtered air from airbox, and last line to feed air on exhaust to allow cat to work fully.
Some people cap and remove lines, since cats usually go wayside, but know this maybe this will help you figure what to do.
Tell us what you decide and love sharing of photos.
- My 3 Bikes:
1. TaoTao TBR7 (My TBR7 Upgrades)
2. Boom Vader (FYI: My Boom Vader Upgrades)
3. 1978 Suzuki SG750
Testing a YouTube Channel
Old 10-01-2024, 09:22 AM   #7
flopsweat   flopsweat is offline
flopsweat's Avatar
For photo reference, these two with the red arrow are connected. I couldn't trace out where the one from the carb side port goes to for a pic, at this time. This is from a 2021 TT250.
2021 CSC TT250
Old 10-01-2024, 04:09 PM   #8
ughmas   ughmas is offline
ughmas's Avatar
Hose in first pic goes to the intake boot (coupling between carb and motor), second one goes to the charcoal canister.
reference: forgive the horrible pics/paint writing, but I took these when I removed my emissions years ago
ID:	32032   Click image for larger version
ID:	32033   Click image for larger version
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 10-02-2024, 09:11 AM   #9
flopsweat's Avatar
I was wondering about removing the emissions canister, it's just kind of annoying and looks dumb. Is there any re-jetting involved with that? So if I take it off and route the "side" port of the carb hose down to the bottom, would I just remove the other canister hose that goes to the tank?
2021 CSC TT250
Old 10-02-2024, 09:40 AM   #10
ughmas's Avatar
yes removing emissions is easy, remove canister and hoses. cap off side port on carb with vaccum cap, same with the port on the tank (or put a breather vent on it, pressure can build up with it completely capped off but has not been an issue for me)
2005 CBR600RR
Old 10-03-2024, 11:56 AM   #11
You can install a longer vent hose on the tank fitting and just run down under the bike alongside the other hoses from the carburetor. If you were to cap the fitting on the tank, you'd have to use a vented gas cap.
Old 10-14-2024, 10:24 AM   #12
flopsweat's Avatar
Does anyone happen know what size fuel line it would be on the underside of the gas tank?
2021 CSC TT250
Old 10-14-2024, 12:10 PM   #13
Do©Hawk   Do©Hawk is offline
My Hawk DLX fuel filter fits 5/16"(8mm) fuel line. I dunno if it is the same as the tt250. I have EFI and high pressure fittings, but the fuel line itself is probably the same size. No guarantee, but something to start with.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
