09-24-2024, 06:27 AM | #1 |
The only way a starter could spin but not engage is if the transfer ratio gear is missing or damaged. a 163FML should be CG200 clone.
Between the starter and the flywheel cover there should be a smaller cover that houses the starter transfer gear. without it the starter cannot engage with the sprag clutch gear on the flywheel. |
09-24-2024, 08:48 AM | #2 | |
09-24-2024, 03:51 PM | #3 | |
There seems to be a common issue with used Australian CG engines from unknown origins that have missing starter transfer gears and or a broken flywheel sprag clutch. I know what it is because I had to fix my CG250 in much the less same way. |
Today, 03:46 AM | #4 | |
If I may ask, what is a CG 250 and thanks for the heads up. I replied to bigdano about my plans which will cover both of your helpful suggestions.
"Let me pour you a tall glass of get over it.... Oh, and here's a straw you can suck it up with!" |
Yesterday, 05:18 AM | #5 |
lol...I feel the same way unless it has to do with a computer, I am in learning mode...constantly.
2022 Hawk 250 |
