Old 09-12-2024, 02:45 AM   #16
danklyrides   danklyrides is offline
Update at 850 miles
I've been on some long trips on my other bikes so haven't ridden the Tank a ton recently. I've tracked fuel mileage for 7 fill-ups so far and my average is 68.4 mpg, best so far is 72.1 mpg.
I installed some small LED visibility lights on the front fork shields. Here are some of the install pics.
I will post some pics of the final result later
Cheers!
Dankly
ID:	31934   Click image for larger version
ID:	31935   Click image for larger version
ID:	31936   Click image for larger version
ID:	31937   Click image for larger version
Old 09-24-2024, 04:02 PM   #17
AndoSama   AndoSama is offline
Hello, I am also a new owner of a tank. Can you tell me what you're getting for max speed? I feel as though mine is a bit underpowered compared to the old falcon 200 it is replacing (they have same engine, just tank has efi)
Old 09-24-2024, 08:57 PM   #18
On a flat road with the boxes mounted but no cargo I can get 53 mph. 54 if I go into a bit of a tuck to cut wind resistance.
I'm also not very pleased with that. I've been hoping that things would loosen up a bit and it would get a little faster with miles...but I just hit 1000 miles today, and no luck.
Old 09-24-2024, 11:12 PM   #19
Here are the pics I promised of my front fork lights installed and working. Next, I really need to do something about the front turn signals. They are really bad!
ID:	32010   Click image for larger version
200 efi, tank, vitacci
