Old 05-30-2024, 09:38 PM   #61
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
I ran out of cut off wheels for my dremel tool but I have these pliers that managed to get the OEM carb screws out without much fuss even with the red thread lock on the bolts. Engineer PZ-57 Japanese pliers($16 on Amazon, a great alternative if you don't have a dremel tool or don't want to spend the money for this one job). You will need M4-.70x20mm screws to replace the OEM headless bolts.
I could only fit one .5mm shim under the needle and still have the white plastic needle retainer clip into the slide piston.
Old 06-11-2024, 11:19 PM   #62
Lowered-Kickstand fix
I posted the 5/8" new lower mounting hole on the rear shock (post #59), which drops about 1.75" and if you drop the front forks about a half inch, you get a solid 2" lowering. I also compressed the preload by about 175 pounds (~ half inch @ 350 pounds per inch). This is a NICE way to stiffen and lower the bike moderately.
BUT, the kickstand is too long now. Aussie mentioned that the kickstand had nice thick walls, so I decided that my weak welding skills could be successfully brought to bear
I took a ~1.25" section out, below the lower spring mounting post:
I set it up pinning it vertically to a red landscaping cinderblock and ground off a section to pin the grounding clamp:
A strip of masking tape was good enough to hold it for the first tack weld, then pulled the tape off and finished it off:
Lovely weld, eh
In my defense, most of that is slag. It was pretty good underneath the mess
I filed off the crap and gave it a flat black finish. Done. The bike leans over nicely. You can even park it with the kickstand uphill now. Plenty strong enough.
This worked out great.
Old 06-12-2024, 10:16 AM   #63
GypsyR   GypsyR is online now
GypsyR's Avatar
I was chicken with mine. Cut 3/4" off first and then about another 3/4".
2023 Templar 250 X
Old 06-18-2024, 05:49 PM   #64
FYI: the rear axle nut is 31mm.
Old 06-18-2024, 09:09 PM   #65
32mm actually.
No, it's 31mm. I bought a 31mm socket and it fits perfectly compared to the loose fit of a 32mm.
Nut 31.22mm
31mm socket 31.4mm
32mm socket 32.2mm (ISO/DIN standard: 32.08 - 32.48mm)
If someone uses a 32mm with an impact to loosen it they are going to deform the nut.
Old 06-18-2024, 10:23 PM   #66
32mm works. A 1-1/4" socket will also work. I use a breaker bar.
Old 06-19-2024, 09:51 PM   #67
Nut 31.22mm
31mm socket 31.4mm
If the nut measures 31.22mm, it is considered to be 32mm nominally by every industrial and automotive measurement standard. Cheap hardware is notorious for being below standards, and often greatly undersized. If a 31mm fits, great, I would use that.
If a 32mm fits, also great, I would use that.
If some standard size fits better than either of them, I would use that.
My point is. Who cares? Use whatever fits the tightest or works. This is like arguing about who got more milk in their glass.
Old 06-19-2024, 11:24 PM   #68
I'm glad the 31mm socket works for you. My 32 works, and I have a 1-1/4" backup that works too. It's just a couple of turns to loosen, tightens easy to, and I like using a breaker bar to make it easy. It's like 55-60 foot pounds. No need to use an impact driver. I don't need to buy a new socket.
Old 06-20-2024, 12:02 AM   #69
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
I used an adjustable wrench because I couldn't find a suitable socket. I think I have a 11/4" socket so if I can find it easily I'll try it next time. Maybe buy the right socket some day.
22 Templar 250
Old 06-20-2024, 10:02 AM   #70
GypsyR's Avatar
I'd appreciate it if like a half a dozen or so posts at the tail of this otherwise very helpful resource thread were deleted.
And then this one too. For the record, until a few posts back I never knew or cared what size the axle nut was. I just loosened and tightened it with whatever it was I had that fit. An adjustable wrench would work. I see it as a non-issue.
2023 Templar 250 X
Old 07-14-2024, 02:22 PM   #71
buzz   buzz is offline
you are so right GypyR. a pair of good pliers wood work.
Old 08-28-2024, 12:59 PM   #72
vividpixel's Avatar
Update: New sensor works great and matches up with the original, but still no 1st gear.
I just bought the last one of these gear position sensors for the Templar X 250, and here's the link in case someone else wants one when they restock: ebay.com/itm/225647471555 (copy-paste to your browser's address bar)
It's sold by XPro. Once I install it, I'll edit this post to confirm that it fits, and at least didn't make the problem any worse (missing indicator for 1st gear).
Templar X 250, current config: 13t/45t, X-ring, PE30, K772 DT
Old 08-29-2024, 10:18 PM   #73
FastKart1   FastKart1 is offline
Originally Posted by Fast_Freddy View Post
The stock headlamp on the Templar is worthless. It's a reflector housing which only works well with incandescent bulbs but it is fitted with a very cheap, low output LED bulb. The only incandescent bulbs that fit the BA-20D base are low wattage and useless for a headlight. I tried installing a better LED but although much brighter, it had a terrible beam pattern (as expected). It was blinding to on-coming traffic with a weak, scattered pattern extending from roadway to sky.
LED headlights require a projector housing to work properly so I decided to test this dual projector replacement headlamp assembly from Amazon.
Attachment 29443
https://www.amazon.com/dp/B0BRQ1ZZL3...roduct_details
Watch for coupons on this item. I got 40% off and today it's 20% off. The same headlamp is also available with a plastic number plate and mounting straps on Amazon for ~$60.
Installation was a breeze. The light assembly is a direct fit replacement for the oem unit. The new light includes a separate pigtail connector to allow you to change the wiring pinout to match the oem 4-pin male harness plug. The oem wire color assignments are listed below:
Green - ground
White - low beam/running light*
Brown - running light/low beam*
Blue - high beam
* Interchangeable. Both are +12v when headlamp switch is 'on'
I wired mine:
OEM - New
Green - black (gnd)
white - white (RL)
blue - brown (HB)
brown - blue (LB)
The results are amazing! The beam pattern is near perfect, the cut-off is clean and well defined and the light output is very impressive. I would definitely buy it again. It is the single biggest improvement to my Templar yet. I don't plan to ride a lot at night but at least now I can and with confidence.
Note: I have no idea if this fits the Templar X or M number plate but the version with a new plate should fit without issue.
This headlight on Amazon says SOLD OUT. I think, no guarantee since I haven't bought one yet, the same one is available from several vendors on Ebay.
https://www.ebay.com/itm/30574459271...mis&media=COPY
Old 09-10-2024, 06:08 PM   #74
https://www.aliexpress.us/item/3256804671542578.html
Sold by Zuumav's official Aliexpress store. I have purchased one, I believe it will bolt right up to our bikes.
Edit: Light received, it does not fit our mounts. You can however use those rubber straps to mount it but you would still need the lower bracket to mount it at four points. It is physically larger than our light and fairing by a fair bit too.
Old 09-10-2024, 06:30 PM   #75
Weresquatch's Avatar
Smile
..very tempting but not sure I'm in a hurry to deal with stuffing all that wire back in there.
Templar X 250
Vespa GTS 300
Vespa ET4 150
Triumph Legend TT 900
