Old 05-26-2024, 04:31 PM   #16
Originally Posted by Williston View Post
Where can I source a cam?
Joe Henner makes a cam for the 172fmm engines.
Old 07-07-2024, 11:49 AM   #17
Templarrider803   Templarrider803 is offline
Templar 250
Looking at the big bore kit and a bigger carb for the Templar 250 standard bike does anybody know how to find an upgrade cam for this bike.
Thanks.
Old 07-07-2024, 08:08 PM   #18
Thanks.
Read the post right above yours...
Old 07-10-2024, 06:02 AM   #19
Does any body know what year the plastics are on the Templar 250 standard model.they look like 2009 ktm 350 sxf but I’m not sure.
Old 07-10-2024, 10:07 AM   #20
GypsyR   GypsyR is online now
GypsyR's Avatar
In the very first post of the "Templar Resource Thread" it says they are basically Suzuki RMZ plastics.
https://www.chinariders.net/showthread.php?t=32177
2023 Templar 250 X
Old 07-10-2024, 08:35 PM   #21
Yeah the Templar m and x have the Suzuki plastics I think the standard Templar has ktm plastic can’t figure what year tho.think it’s 2009 sxf 350
Old 09-06-2024, 06:20 PM   #22
QA50   QA50 is offline
Hawk DLX Big Bore 72.5 Kit
Does anyone know for sure if the 72.5mm Big Bore Kit sold at Aliexpress will directly fit on the 2022 Hawk DLX?
Old 09-06-2024, 07:16 PM   #23
XLsior   XLsior is offline
XLsior's Avatar
if the hawk DLX uses a standard CG250 67mm piston then the likelyhood of any kit larger than 70mm fitting without major case modification is unlikely.
The OD cylinder skirt is 74mm a 72.5mm piston would mean a less than 1mm cylinder skirt wall thickness which is too thin.
