Old 08-01-2024, 01:33 PM   #76
According to tracking, it should be delivered tomorrow.
Old 09-02-2024, 07:13 AM   #77
Originally Posted by dugndeep View Post
I had to remove the reverse back-up alarm,I don't need to let this end of the county know I'm backing up.
I need to do the same. For the life of me I can't locate exactly were it's located. That thing is annoying. Lol
Old 09-03-2024, 12:17 PM   #78
dugndeep   dugndeep is offline
That reverse alarm is under the seat on the left side,looks like a cdi that's on the tao Bull 200,if anybody gets one & can't stand half of the state knowing you are backing up,lol
My camera anymore doesn't take a good picture
ID:	31903   Click image for larger version
ID:	31904   Click image for larger version
ID:	31905   Click image for larger version
ID:	31906   Click image for larger version
Old 09-03-2024, 12:20 PM   #79
Congratulation,I like mine,I just couldn't go back to 2 wheel drive.Pulling a cart loaded down with what-ever,plus in 4-wheel drive it will go in the snow.
Old 09-03-2024, 12:22 PM   #80
Originally Posted by ndlangub View Post
dugndeep
Can you eShare the Service manual with Parts Catalog for the Vitacci Terminator aka Linhai LH300? Needing to get a full replacement Transmission, so need the service manual parts numbers - another ATV rear ended me and the transmission is now stuck in HI gear and won't slip into Neutral or Reverse any longer.
Then will need to research where I can buy the replacement transmission.
Give me a minute & I'll look-up the trans number.
Old 09-03-2024, 12:25 PM   #81
These are the same as Massimo at Tractor supply
21515sc
TRANSMISSION ASSY 4WD
https://www.massimomotor.com/21515sc...h-Power-Clutch
Their all made by Linhai
Old 09-03-2024, 12:27 PM   #82
Thanks, you don't know how much i appreciate it. lol Man that beeper is annoyingly loud.
Old 09-03-2024, 12:29 PM   #83
21515sc Transmission Assy
$1,243.13
Old 09-03-2024, 12:33 PM   #84
You could probably buy that transmission cheaper on Aliexpress but shipping cost is gonna be high though?
Old 09-03-2024, 12:36 PM   #85
I never thought about it but you might could wrap some black tape around it,I would like to have something other than the light to let you know your are in reverse so you don't jump on it & hit the gas & throw yourself over the handlebars,I've almost done it not knowing I was still in reverse.
Old 09-03-2024, 12:43 PM   #86
Yeah, i've though of doing that too. My Hawk had the beeper for the turn signals. I taped it up to quiet it down. Kept me from riding 20 mile with the turn signal on. lol
Old 09-03-2024, 12:47 PM   #87
They have another transmission that instead of SC after the number they have an SD after the 21515sd
the sc stands for speed sensor.
Probably chipped a tooth inside transmission,you might could buy the individual gear??/
Old 09-03-2024, 04:14 PM   #88
dugndeep
http://linhai.com.ro/wp/wp-content/u...-DragonFly.pdf
download schematic first,it might not be as bad as you think,maybe drop the transmission
These all use the same transmissions
Might be like my starter clutch,just hung up
Could it just maybe be the shift rod?
Old 09-03-2024, 04:30 PM   #89
I had another NGK plug go bad on me.I'm done with NGK,I went out and bought a Champion 4 pak of 809(RA6HC)
