Old 09-01-2024, 02:37 PM   #16
J4Fun   J4Fun is online now
ProDigit, two questions, I see from above what tire pressure you’ve been running, what is the maximum pressure stated on the side of your tire? That’s question 1 because my Hawk 250 DLX manual calls for 40 psi on the rear tire and the tire itself says 32 psi max. I do believe the manual may be incorrect. Second, your post above you use 0.04-0.05” I’m sure you meant.004-.005” right? If you changed the intake to .002” it would be quieter and cooler, I agree. Was looking at your thread and sounds like your having fun with the bike. My thoughts
Old Yesterday, 02:39 AM   #17
Thanks, yes, my bad.. .002 for intake, and .004" for exhaust. One zero off. It's the smallest blade in the feeler gauge tool.
I was thinking in mm, writing in inch.
The outside tire of my Lifan Xpect stated 40psi. I'm running roughly 35psi cold, and 38psi hot,both front and rear, 1psi tolerance.
The bike can actually run fine at 10psi, but really needs a good 28-30psi minimum, to roll efficiently.
