Old 08-16-2024, 10:24 PM   #16
bigdano711's Avatar
Doesn't get much better than that. Did the stumble go away? What manual are you referring to? The one that came from CSC with the bike or a Nibbi manual? Here's what I got for Nibbi:
Old 08-19-2024, 10:51 PM   #17
Sdmfjon   Sdmfjon is offline
Update.
It's too rich. But like a hair too rich in the midrange. Random stumble coming off idle. Sounds fat like a tractor.
Going to try two things.
First. Raise the needle clip from position 3 to 2.
If that is unfavorable I'm going to try the factory combo from the PE28FL. This would lower the main jet to 112 and change the needle clip to position 4.
My manual looks different than that one. I have the factory settings for the "PE**FL" lineup and the clamp on lineup.
Old 08-21-2024, 01:11 PM   #18
Update. That worked. No stumbling, no gassy smell.
I still can't crack throttle from idle to anything 1/2 or beyond. If I bring the bike off idle it's fair game. Oh well. I don't want to spend 300 dollars on a really nice genuine pumper carb like my hondas have.
Final tune for now.
Stock bike. Emissions removed and a Nibbi PEZ28 fitted.
38 idle jet
Needle position 2
Air screw 1 1/2
Main jet 115.
Old 08-21-2024, 01:46 PM   #19
dirtbkr188's Avatar
Strictly a suggestion, you only need a screwdriver and some time - try turning the air screw IN a 1/4-turn (to richen the pilot circuit), ride the bike and see if the off-idle hesitation lessens. If so, try another 1/4-turn and test ride, until you think the hesitation is gone. If you get to being only a 1/2-turn from seated, then you might want to bump the pilot up to a #40.
Just my 2¢...
Old 08-21-2024, 02:48 PM   #20
I started with the 40. It made me have to put the air screw almost 3 turns out to achieve highest idle.
The 38 puts me dead between 1 1/4 and 1 1/2.
Old 08-21-2024, 06:25 PM   #21
red2003   red2003 is offline
Just my 2¢...
1/4 turn on the air screw of a Nibbi is HUGE. I am running a PE28 and 1/16 turn on the air screw creates or removes an off idle stumble. Luckily, like you said, on a Nibbi it's easy to fuss with. I'm sure the OP could get the off idle stumble out with a few minutes of fine tuning.
Old 08-22-2024, 08:35 AM   #22
Zapkin   Zapkin is offline
Zapkin's Avatar
I have the nibbi on my 2022 hawk 250 and using this video:
solved all of my carb situations and the bike runs great. check it out.
2022 Hawk 250
Old Yesterday, 11:21 PM   #23
Update. Still not right.
I think the 115 is too rich and causing issues.
I'm going to go from 115 to 112. Which I'm pretty sure is going to throw everything else off.
