Old Yesterday, 07:06 AM   #1
Ben4851   Ben4851 is offline
Timing chain 167 fml or 169 fml
Hello chinariders!
I bought benyco tekken/barton hyper/zipp vz 5 but previous owner swapped engines to (supposedly) 167 fml or 169 fml and i cannot find new timing chain for this engine anywhere.
Timing chain im looking for has dimensions as follow:
-distance between outside pins edges is 85mm
-distance between inside pins edges is 40mm
-link lenght 115mm
-104 links
I think it might be one of zongshen engines but i cannot find dimensions of these timing chains. I will attach pics of mine, maybe someone will help please
ID:	31865   Click image for larger version
ID:	31866   Click image for larger version
ID:	31867   Click image for larger version
ID:	31868   Click image for larger version
Old Yesterday, 07:53 AM   #2
Is there no engine model stamped/printed on the engine block behind the gearshift?
Old Yesterday, 10:34 AM   #3
Thanks for quick reply Thumper, i will ask my mechanic do give it another look behind the gearshift but we couldnt find any marks on engine :/
Old Yesterday, 11:37 AM   #4
Mechanic! You found a mechanic to work on a Chinese bike. Whoo... lucky!
The engine model number and serial number should be in front of the gear shift post. It faces the left side. Behind the lever, but in front of the shift post itself. Not behind the lever where the sprocket is.
I found an example. It is a blown up insert in this photo, and you can see it on the engine on the lower left side in the photo as well.
Old Today, 02:23 AM   #5
Thanks a lot for this pic! I wouldnt call myself lucky because i have ordered 3 timing chains already and none of them seems to fit correctly
Old Today, 02:28 AM   #6
Yay, mechanic replied - its ZS169FMM! Now anyone maybe knows where the hell can i get timing chain for this thing? ������
Old Today, 02:53 AM   #7
https://a.aliexpress.com/_Eve9K3b found it! Its silly that i couldnt find that chain when i searched for 169fmm but when i type ZS169FMM - here it is! Thank you guys for helping me to identify the engine, keep your fingers crossed for me hope fully being able to ride my bike soon!
Old Today, 07:49 AM   #8
dirtbkr188's Avatar
The link doesn't work...
