Old 08-09-2024, 02:45 PM   #1
PeteTheCat   PeteTheCat is offline
PeteTheCat's Avatar
Hawk250dlx fuel?air?spark? Problem
hey guys i’ve been having a battle with my 2022 hawk DLX the past 2-3 months. i can’t seem to get it running properly.
bike turns on and has a rough low idle. when given gas it either dies or bogs
(when is dies smoke comes out exhaust)
i’ve tried many different things and have replaced over $400+ worth of oem parts.
REPLACED:
air filter
fuel pump & assembly
throttle body
spark plug
TRIED:
compression test (155psi)
different gasolines/ additives
spark test(plenty of spark)
fuel pressure test(in spec)
pulled out the injector and it’s spraying fine.
The problem originally started when i was riding and it started sputtering/losing power so i took it home.
Anyone else have this problem? any solutions? i’m thinking it could possibly be ECU or piston sensor but i replaced piston position sensor about 700 miles ago.
any help is appreciated
Old 08-10-2024, 08:35 AM   #2
Do©Hawk   Do©Hawk is offline
Have you scrutinized your wiring harness for loose connections or exposed wire? How about the vacuum system. I would think you would show a check engine light if one of the sensors was bad. Have you adjusted the valves?
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
Old 08-21-2024, 04:28 PM   #3
TitusvilleRmiles   TitusvilleRmiles is offline
check exhaust pipe to see if it is full of water or liquid. remove pipe and check
Old 08-21-2024, 06:49 PM   #4
CheapThrills   CheapThrills is offline
You checked so much, maybe you are right about the ECU. :(
- My 3 Bikes:
1. TaoTao TBR7 (My TBR7 Upgrades)
2. Boom Vader (FYI: My Boom Vader Upgrades)
3. 1978 Suzuki SG750
Testing a YouTube Channel
Old 08-21-2024, 09:48 PM   #5
buzz   buzz is offline
Try another spark plug,seen bad ones new out the box.
Old 08-22-2024, 08:53 AM   #6
You need to adjust the valves. These bikes come from the factory with little or no gap in the valves. Once the engine starts and warms up, the valves stop sealing and loose compression. Take my advise and stop throwing money at it. Yu can thank me later. lol
bogging, dlx efi, help identifying
