08-11-2024, 02:59 PM | #16 | |
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 08-11-2024 at 04:12 PM. |
08-11-2024, 03:20 PM | #17 |
New one ordered.
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
Yesterday, 07:21 PM | #19 |
As embarrassing as it may be, I think I just had a loose cable.
Lesson learned (though I'm sure I'll need a refresher at some point) Don't overlook the simple stuff creating a problem you don't have.
Yesterday, 08:15 PM | #20 | |
Positive battery post to thick wire terminal and ground the body of the starter to the negative post, and the starter should run, with high torque! You do have to clamp it on there and if you don't, there will be sparks (high amperage device).
Yesterday, 10:16 PM | #21 |
Maybe I never got the positive clamped onto the starter when I tested it directly to the battery?
