Old 08-09-2024, 01:45 PM   #1
PeteTheCat   PeteTheCat is offline
PeteTheCat's Avatar
Hawk250dlx fuel?air?spark? Problem
hey guys i’ve been having a battle with my 2022 hawk DLX the past 2-3 months. i can’t seem to get it running properly.
bike turns on and has a rough low idle. when given gas it either dies or bogs
(when is dies smoke comes out exhaust)
i’ve tried many different things and have replaced over $400+ worth of oem parts.
REPLACED:
air filter
fuel pump & assembly
throttle body
spark plug
TRIED:
compression test (155psi)
different gasolines/ additives
spark test(plenty of spark)
fuel pressure test(in spec)
pulled out the injector and it’s spraying fine.
The problem originally started when i was riding and it started sputtering/losing power so i took it home.
Anyone else have this problem? any solutions? i’m thinking it could possibly be ECU or piston sensor but i replaced piston position sensor about 700 miles ago.
any help is appreciated
Old Yesterday, 07:35 AM   #2
Do©Hawk   Do©Hawk is offline
Have you scrutinized your wiring harness for loose connections or exposed wire? How about the vacuum system. I would think you would show a check engine light if one of the sensors was bad. Have you adjusted the valves?
2022 Hawk DLX EFI
* 17T Front / 47T Rear / 428 x-ring chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Custom cutting board skid plate
* Debadged (I don't like to brag about the
superior strength!)
* Top speed, GPS verified, as equipped: 68
mph (so far)
bogging, dlx efi, help identifying
