Old 08-07-2024, 08:32 PM   #1801
Chewalla   Chewalla is offline
Originally Posted by Nutcracker View Post
Thanks for the info. Got some more research to do. I don't believe you can go any higher than a 13 tooth front drive. There's just not enough clearance if it binds your looking at a broke case. I have a 12 tooth that I believe should fit from my sons Honda 150f but that's the opposite I want to go. What I'm really wanting is a complete back rim with street tire and the proper tooth count. Not sure what rim is going to fit yet...I believe the bike has the power to maintain 55 mph at a much lower RPM. I did hit 70mph yesterday. "67 my speedo is off 3 mph"... Motor was completely wound out.. I hit 300 miles and decided to push it. Only problem is the chain completely stretched and has a few stiff links..
Check out “custom everything” on YouTube and peep his adv build on the Templar x, big bore and running 14t front 40t rear, says it runs 83 mph at 6500 rpm
