05-09-2024, 06:49 AM | #1 |
Where can I get shark 250 front brake caliper
So I have this 17" 19" Chinese enduro that has a single cylinder front brake that looks like the posted pictures and I'm trying to find a replacement. It's a shark 250 enduro. Where can I get one that will work?
05-09-2024, 06:57 AM | #2 |
05-09-2024, 08:02 AM | #3 |
05-09-2024, 09:36 AM | #4 | |
05-09-2024, 01:07 PM | #5 | |
Is it this one if taken off the mount? Because the bolt spacing is not 2.4ish inches on this one. |
05-10-2024, 01:37 AM | #6 |
I can't even find that style for the front. I almost wonder if it wouldn't be easier to change out for a 2 piston caliper like the Hawk and other standard fork bikes use. The mounts on the fork lower may be the same. I could measure the spacing of mine to see if it is.
05-11-2024, 11:18 AM | #7 | |
Can I use a two piston one for this disc? Is it compatible? Which one should I use? I'm a bit confused really. |
05-14-2024, 02:50 PM | #8 |
Any idea if the hawk front brakes would mount?
05-16-2024, 01:20 AM | #9 |
No clue, but the bolt spacing on the forks of the Hawk is 2.4 inches/61mm (roughly) from center to center.
07-03-2024, 03:52 PM | #10 |
FVRITO Brake Caliper and Pads for 110cc 125cc 150cc 200cc 250cc 196cc 6.5HP Coleman kt196 yerf dog gx150 Kandi Baja RTK200 Go Kart Dune Buggy Taotao Roketa Sunl Kazuma Chinese ATV Quad Golden https://www.amazon.com/dp/B097ZN67QY...KR&starsLeft=1
Do you think this will fit? |
07-03-2024, 03:56 PM | #11 |
Just finished mounting some of the engine mounts, but wanna try to make sure I can get a brake caliper.
07-03-2024, 07:48 PM | #12 | |
07-11-2024, 08:25 AM | #13 |
Oh, where can I get a compatible caliper for it cheap? I already have the line and the master cylinder/brake handle.
