05-26-2024, 04:31 PM | #16 |
Joe Henner makes a cam for the 172fmm engines.
07-07-2024, 11:49 AM | #17 |
Templar 250
Looking at the big bore kit and a bigger carb for the Templar 250 standard bike does anybody know how to find an upgrade cam for this bike.
Thanks. |
07-07-2024, 08:08 PM | #18 |
Read the post right above yours...
07-10-2024, 06:02 AM | #19 |
Does any body know what year the plastics are on the Templar 250 standard model.they look like 2009 ktm 350 sxf but I’m not sure.
07-10-2024, 10:07 AM | #20 |
In the very first post of the "Templar Resource Thread" it says they are basically Suzuki RMZ plastics.
https://www.chinariders.net/showthread.php?t=32177
2023 Templar 250 X |
07-10-2024, 08:35 PM | #21 |
Yeah the Templar m and x have the Suzuki plastics I think the standard Templar has ktm plastic can’t figure what year tho.think it’s 2009 sxf 350
09-06-2024, 06:20 PM | #22 |
Hawk DLX Big Bore 72.5 Kit
Does anyone know for sure if the 72.5mm Big Bore Kit sold at Aliexpress will directly fit on the 2022 Hawk DLX?
09-06-2024, 07:16 PM | #23 | |
if the hawk DLX uses a standard CG250 67mm piston then the likelyhood of any kit larger than 70mm fitting without major case modification is unlikely. The OD cylinder skirt is 74mm a 72.5mm piston would mean a less than 1mm cylinder skirt wall thickness which is too thin. |
