Old 06-15-2024, 10:00 AM   #61
dugndeep   dugndeep is offline
Now I'm looking to purchase a service manual for the Linhai 260/300 4x4 atv.I have a couple already downloaded & saved on my computer but I want a paper back version.I just don't know if my printer could print out 360 pages plus whether I got the ink to do that.
Old 07-09-2024, 10:37 AM   #62
I've been going around the atv trying to find all the zerk grease fittings and applying some grease to them.I think I have found them all & am now wondering about the front hub carrier bearings.Their like the old cars & tractors ect & their not a sealed bearing.
Old 07-09-2024, 10:47 AM   #63
The 2wdhub carrier looks like it has a place for a zerk fitting.To where the 4wd does not,I was just wondering if I could drill & tap for a zerk fitting?
Old 07-09-2024, 10:49 AM   #64
I would drill and tap it to install a grease zerk.
Old 07-09-2024, 10:54 AM   #65
That's the 2wd version above & I don't know if that is a threaded hole for the zerk fitting or not.The 4wd doesn't have that & has the splined shaft running through it.
Old 07-09-2024, 10:58 AM   #66
I suppose you might could on the back side of the rotor.
Old 07-09-2024, 11:17 AM   #67
I think they skimped on the grease in the fittings,some I don't think they put any grease in & that's why I'm worried about the front axle bearings.
Old 07-09-2024, 11:23 AM   #68
I'll have to take the wheel off,cotter pin & nut just to see what kind of grease is in there.There's a grease fitting on the steering shaft,I had to take the front cover off to get to it & they must have never put any grease in it,so much easier to steer after putting grease in the steering bushing.
Old 07-09-2024, 11:26 AM   #69
As long as the zerk doesn't interfere with the bearings or shaft, I wouldn't think you would have any issues with installing one.
Old 07-09-2024, 11:42 AM   #70
Parts catalog.I'm trying,one picture is to big & the other is so small you can't hardly see it.I'll just have to take the hub carrier off to see.
Name:	Screenshot 2024-07-09 at 11-40-34 LH300_Norway.xls - Linhai LH 300 Parts Catalogue.pdf.jpg
