Old 05-09-2024, 06:49 AM   #1
jatgm12   jatgm12 is offline
Where can I get shark 250 front brake caliper
So I have this 17" 19" Chinese enduro that has a single cylinder front brake that looks like the posted pictures and I'm trying to find a replacement. It's a shark 250 enduro. Where can I get one that will work?
Old 05-09-2024, 06:57 AM   #2
https://ibb.co/qRF2rQk
https://ibb.co/Xb7DV6h
These
Old 05-09-2024, 08:02 AM   #3
Look here. https://www.vmcchineseparts.com/coll...brake-calipers
Old 05-09-2024, 09:36 AM   #4
Do you happen to known which version it is? I don't see any that look exactly the same and I'm not sure how to see if it's the same.
Old 05-09-2024, 01:07 PM   #5
https://www.vmcchineseparts.com/prod...-taotao-db10-1
Is it this one if taken off the mount? Because the bolt spacing is not 2.4ish inches on this one.
Old 05-10-2024, 01:37 AM   #6
I can't even find that style for the front. I almost wonder if it wouldn't be easier to change out for a 2 piston caliper like the Hawk and other standard fork bikes use. The mounts on the fork lower may be the same. I could measure the spacing of mine to see if it is.
Old 05-11-2024, 11:18 AM   #7
If you could measure that would be cool.
Can I use a two piston one for this disc? Is it compatible? Which one should I use? I'm a bit confused really.
Old 05-14-2024, 02:50 PM   #8
Any idea if the hawk front brakes would mount?
Old 05-16-2024, 01:20 AM   #9
No clue, but the bolt spacing on the forks of the Hawk is 2.4 inches/61mm (roughly) from center to center.
Old 07-03-2024, 03:52 PM   #10
FVRITO Brake Caliper and Pads for 110cc 125cc 150cc 200cc 250cc 196cc 6.5HP Coleman kt196 yerf dog gx150 Kandi Baja RTK200 Go Kart Dune Buggy Taotao Roketa Sunl Kazuma Chinese ATV Quad Golden https://www.amazon.com/dp/B097ZN67QY...KR&starsLeft=1
Do you think this will fit?
Old 07-03-2024, 03:56 PM   #11
Just finished mounting some of the engine mounts, but wanna try to make sure I can get a brake caliper.
Old 07-03-2024, 07:48 PM   #12
alex_in_az   alex_in_az is offline
that really looks like a TBR7 fork and caliper to me
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
