Old 06-24-2024, 08:41 AM   #1
Hangkai 18HP 2 Stroke Outboard
Well I decided to get back into fishing again so i bought a nice used 15' aluminum boat and in the true Chinariders spirit, I ordered a Hangkai 18HP 2 stroke outboard off of Amazon that was fairly cheap compared to the name brand stuff. https://amzn.to/3xxVFOq I also installed an Tach/Hour meter. https://amzn.to/3REYNii
My first impression when I opened the box was it looked like a nice, well built motor. It included everything needed like the tank, gas hose, extra spark plugs, Impeller and gaskets. I took it out of the box and set it on my motor stand that i built. As per instructions, i added gear oil to the foot. I did a 25:1 mixture for the break-in as per instructions. Need to run this mixer for the first 10 hours then switch to a 50:1 mixture after. I hooked up the water to the foot, then pumped the bulb up on the gas line till hard. Pulled the choke and gave it a pull on the rope. I was shocked that it started on the first pull. Can't wait to get my trailer in so I can go take it for a ride.
