06-18-2024, 05:43 AM | #1 |
Hard kickstart this morning.
I have a bike with a 200cc 169FML engine.
This morning my battery was dead, so I had to kickstart the little beast. I found that it was extremely hard to get it to turn over, almost as if there is way too much compression. After charging the battery it started easily, but now I understand why it sometimes kicks the started clutch out. So, could it be valve lash? Intake is .005 and exhaust is .008. Is the exhaust too much? I have noticed a lack of real performance. A while ago we had a seriously hot day, and the bike came alive with plenty of power, so I am thinking that it could be that the hotter engine had something to do with it, hence my leaning towards bad valve clearances. I am also considering the fact that the timing chain could be stretched, or has even jumped a tooth as the idling isn't the smoothest. The bike has done more than 50 000 kilometres on this engine, so it is a real stalwart.(not going to mention the peripheral parts that are not quite as durable.) |
06-18-2024, 08:51 AM | #2 |
Valve lash wouldn't be the cause. Maybe carbon build up in the combustion chamber? If it has a timing chain it may have an automatic compression release on the cam that wasn't engaged.
06-18-2024, 03:24 PM | #3 |
Muffler Bearing
06-22-2024, 01:41 PM | #4 |
Did you try to push start the bike?
kickstart issues |
