Old 05-30-2024, 09:38 PM   #61
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
I ran out of cut off wheels for my dremel tool but I have these pliers that managed to get the OEM carb screws out without much fuss even with the red thread lock on the bolts. Engineer PZ-57 Japanese pliers($16 on Amazon, a great alternative if you don't have a dremel tool or don't want to spend the money for this one job). You will need M4-.70x20mm screws to replace the OEM headless bolts.
I could only fit one .5mm shim under the needle and still have the white plastic needle retainer clip into the slide piston.
Old 06-11-2024, 11:19 PM   #62
Lowered-Kickstand fix
I posted the 5/8" new lower mounting hole on the rear shock (post #59), which drops about 1.75" and if you drop the front forks about a half inch, you get a solid 2" lowering. I also compressed the preload by about 175 pounds (~ half inch @ 350 pounds per inch). This is a NICE way to stiffen and lower the bike moderately.
BUT, the kickstand is too long now. Aussie mentioned that the kickstand had nice thick walls, so I decided that my weak welding skills could be successfully brought to bear
I took a ~1.25" section out, below the lower spring mounting post:
I set it up pinning it vertically to a red landscaping cinderblock and ground off a section to pin the grounding clamp:
A strip of masking tape was good enough to hold it for the first tack weld, then pulled the tape off and finished it off:
Lovely weld, eh
In my defense, most of that is slag. It was pretty good underneath the mess
I filed off the crap and gave it a flat black finish. Done. The bike leans over nicely. You can even park it with the kickstand uphill now. Plenty strong enough.
This worked great.
Old 06-12-2024, 10:16 AM   #63
GypsyR   GypsyR is offline
GypsyR's Avatar
I was chicken with mine. Cut 3/4" off first and then about another 3/4".
2023 Templar 250 X
Old 06-18-2024, 05:49 PM   #64
FYI: the rear axle nut is 31mm.
Old 06-18-2024, 09:09 PM   #65
32mm actually.
No, it's 31mm. I bought a 31mm socket and it fits perfectly compared to the loose fit of a 32mm.
Nut 31.22mm
31mm socket 31.4mm
32mm socket 32.2mm (ISO/DIN standard: 32.08 - 32.48mm)
If someone uses a 32mm with an impact to loosen it they are going to deform the nut.
Old 06-18-2024, 10:23 PM   #66
32mm works. A 1-1/4" socket will also work. I use a breaker bar.
Old 06-19-2024, 09:51 PM   #67
Nut 31.22mm
31mm socket 31.4mm
If the nut measures 31.22mm, it is considered to be 32mm nominally by every industrial and automotive measurement standard. Cheap hardware is notorious for being below standards, and often greatly undersized. If a 31mm fits, great, I would use that.
If a 32mm fits, also great, I would use that.
If some standard size fits better than either of them, I would use that.
My point is. Who cares? Use whatever fits the tightest or works. This is like arguing about who got more milk in their glass.
Old 06-19-2024, 11:24 PM   #68
I'm glad the 31mm socket works for you. My 32 works, and I have a 1-1/4" backup that works too. It's just a couple of turns to loosen, tightens easy to, and I like using a breaker bar to make it easy. It's like 55-60 foot pounds. No need to use an impact driver. I don't need to buy a new socket.
Old 06-20-2024, 12:02 AM   #69
Fast_Freddy   Fast_Freddy is offline
Fast_Freddy's Avatar
I used an adjustable wrench because I couldn't find a suitable socket. I think I have a 11/4" socket so if I can find it easily I'll try it next time. Maybe buy the right socket some day.
22 Templar 250
Old 06-20-2024, 10:02 AM   #70
GypsyR's Avatar
I'd appreciate it if like a half a dozen or so posts at the tail of this otherwise very helpful resource thread were deleted.
And then this one too. For the record, until a few posts back I never knew or cared what size the axle nut was. I just loosened and tightened it with whatever it was I had that fit. An adjustable wrench would work. I see it as a non-issue.
2023 Templar 250 X
