06-18-2024, 08:16 AM | #1 |
Vitacci scooter bolt torque specs
Has anyone found any type of service manual with torque specs? I found a bolt on my force 200 loose in a critical area. It's on the right side just in front of the rear axle and connects to the bottom of the motor. Obviously don't want to over tighten and break the engine cases but it seems like it needs to be tight enough to never come loose? Ideas?
06-18-2024, 08:39 AM | #2 |
Tighten until it snaps then back off half a turn.
I would use standard metric bolt torque specs. Google metric bolt torque specs and you'll find PDF charts. |
