Old 11-10-2023, 10:43 AM   #1
RAVEN71   RAVEN71 is offline
Raven 250 2023 Wiring Speedo ?
Anyone have the Raven 250 2023 Wiring Speedo ? Trying to install the
Zanella RPS Hawk Digital Speedometer, not much luck.
Thanks in advance
Old 11-26-2023, 02:15 AM   #2
rjs7734rav   rjs7734rav is offline
There is a review on Amazon that details what is needed to be done when wiring that speedometer to a Raven
Name:	Screenshot_20231119_225617_Samsung Internet.jpg
Old 12-02-2023, 02:50 AM   #3
I installed this on a 2023 BSR Raven 250.
The individual wires are removed from the plug with the help of a small jeweler's type screwdriver.
On the front connector just match up the colors except for the red/white wire, it needs to be joined with the blue/white wire.
FRONT: red/white to blue/white
At the rear connector once again match up the colors except for the light green/red stripe, it joins the green/red stripe wire from the wires you removed from the original plug to make the "N" light work. The blue/white wire joins the blue/white wire in the other plug at the battery position and the purple is unused.
REAR: light green/red to green/red
You will need to remove a small section of the mounting plate to allow for the wire harness (don't forget to paint your cut to prevent rust).
Everything works just fine but at 60mph on the new speedometer, the GPS speed is 55mph. I haven't tried to adjust that yet, but I will in the future.
ID:	30480   Click image for larger version
ID:	30481   Click image for larger version
ID:	30482   Click image for larger version
Old 12-02-2023, 03:30 AM   #4
bigdano711's Avatar
I discovered the exact same thing with my digital dash. I have changed the tire size from 21" (actual tire size) to 19" on the dash, but have not conducted another GPS speed test. Maybe tomorrow.
John 2:15 So He made a whip out of cords and drove all from the temple area, both sheep and cattle; He scattered the coins of the money changers and overturned their tables.
Old 06-02-2024, 08:23 AM   #5
My Zanella goes dark when I shift gears, doesn't matter which gear. Then going back to neutral the Zanella reboots, and all lights up, until the next gear shift.
Any thoughts / suggestions ?
Thanks, I have a few hours invested in troubleshooting.
250 raven, rpms, speedometer
