Old 04-24-2024, 07:43 AM   #1
dugndeep   dugndeep is online now
Linhai 300cc 4x4 starter clutch
Went to start the atv yesterday and wouldn't turn over.I could hear the starter whirling but that was it.I thought maybe a pin or something had come out of the starter gear & wasn't allowing the starter gear to spin,just the shaft.So I went to taking it apart,air filter box to expose the starter,then 2 screws that held the starter on & found out the starter was okay so it has to be the starter clutch.Went to youtube and found a video which pretty much explains it all on how to replace the starter clutch.
Old 04-24-2024, 07:45 AM   #2
So got on Ebay and ordered a starter clutch,part number 23706 and a gasket,part number 23617.Just to be sure I get a gasket I ordered another gasket from a different seller.
Old 04-24-2024, 08:34 AM   #3
I started this thread by using the Linhai name which is who it is made by,the name on the tank is Vitacci but it has Linhai stamped everywhere so.......
Old 04-24-2024, 09:01 AM   #4
I might not need a gasket but you never know plus the starter clutch might be a weak part on these China made atv's so I'll have extra gaskets.I never had a bit of trouble out of the Tao Motor Bull 200 starter or starter clutch I reckon.It was a good starting & running made in China atv.I am going to have to break it out to use till my parts come in for the Linhai/Vitacci.The Bull 200 should start right up because the only fuel it has ever had was non-alcohol,just like the Linhai.I use non-alcohol in all my small engines.
Old 04-28-2024, 10:12 AM   #5
Got things apart,just waiting on parts.
Name:	DSCI0004 - Copy.JPG
ID:	31345   Click image for larger version
Name:	DSCI0005 - Copy.JPG
ID:	31346   Click image for larger version
Name:	DSCI0006 - Copy.JPG
ID:	31347   Click image for larger version
Name:	DSCI0007 - Copy.JPG
ID:	31348   Click image for larger version
Name:	DSCI0008 - Copy.JPG
Old 04-28-2024, 10:23 AM   #6
I got lucky & the cover come off without tearing up the gasket.Oil pump is right there under the magneto.
Old 04-28-2024, 10:44 AM   #7
The Magneto bolt size is M8-1.25 & I don't have any long enough to pull off the magneto with the Harmonic balance puller I got,the point doesn't come off my puller so it's 2" just to get to the magneto & about 4" to pull it off.
Old 04-28-2024, 10:47 AM   #8
I was lucky I wasn't down the creek somewhere or at the river when the starter clutch went bad.It would have been hell to get it back to the house to work on it.Lucky I had just got on it in the barn.
Old 04-28-2024, 04:39 PM   #9
Jb2487   Jb2487 is offline
Thanks for sharing the video of fixing the starter clutch, do I have to have the harmonic puller to get to the starter clutch or is there another method.
Old 04-28-2024, 06:30 PM   #10
You might could use a jaw puller that goes behind the magneto if it will grab a hold of the back side.You got to watch though,you might gouge the magneto and throw it out of balance.I believe I would just go with a harmonic balancer puller.You can buy a whole puller kit with different size bolts for less than $25 dollars with free shipping on Ebay.That's what I did.
Old 04-29-2024, 08:59 AM   #11
I wonder if there is anyway possible to roll start one of these that has automatic transmission?This one does have hi-low forward.
Old 04-29-2024, 09:23 AM   #12
Probably going to order another starter clutch just to have one.I noticed the starter made funny noises sometimes starting, when I first got it.Would hear a clunk every now & then.Like the clutch might have been hanging up,idk.I don't know who you would call a name brand manufacturer of these starter clutches to maybe order a better one?Probably just order one from Aliexpress.I didn't want to wait on the slow boat from China this time so I paid more to have one shipped from here & not China.
Old 04-29-2024, 09:26 AM   #13
My starter clutch will be here today,still haven't got the magneto off yet,still trying to find longer M8-1.25 locally without having to order them off the internet.My local Fastenal doesn't have the length I need in stock.
Old 04-29-2024, 11:22 AM   #14
I’m not 100% sure but from what I have heard I don’t think so.
Old 04-29-2024, 11:25 AM   #15
I noticed when my atv is cold it starts right up but after it has warmed up I’ll have to give a little throttle while starting and it’s starts up fine and there have been times it sounded clunky too.
