Question about hand levers
Does anyone happen to know which bike(s) the hand levers on the CSC TT250 are patterned after? I’d like to get some adjustable folding levers that fit the stock clutch perch and front master cylinder, but I’m not sure which ones would fit. Thank you in advance.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come. |
I can't say which ones they're similar to, but I have these on my TT. I had to grind off the ball-end of the stock levers to fit my hand guards, but eventually wanted these smaller ones for a better fit for my hands. They fit just fine, other than being maybe a half inch away from the master cylinder and left control module instead of snugged right against them like the stock ones.
2021 CSC TT250 |
Likely the same levers the Hawk and other Hawk-like bikes use, but I can't confirm that 100% so some salt grains required.
Honda Grom, Rebel, and most of the other small engine Honda motorcycles.
I use the universal levers on several bikes. These will work on the TT250. https://amzn.to/3IP7l1h
#5 | |
If you don't already have braided SS brake lines, they are worth it. They really eliminate sponginess altogether.
Thank you for all the replies.
