Old 02-21-2024, 11:38 AM   #1
solidsnake2431   solidsnake2431 is offline
Supermoto Rim Hub Conversion?
I just got what I thought would fit the CRF 250L supermoto rim set for my Templar. Turns out the inside diameter for the bearings is about half the size of the Tenplar that has the more standard size axle bolt diameter. My question is if I buy Tenplar hubs can I switch them out so I can use thease rims? Could I use the spokes that came on here or would I need different length spokes...?
If I can't make them work with just changing out the hubs I might return them and then just get supermoto tires for the stock rims and try and squeeze them onto the skinner rims.
Old 02-23-2024, 04:39 PM   #2
recracer   recracer is offline
recracer's Avatar
I think i would see if you could swap out your Wheel bearings, if i am understanding the problem . you can measure what you need and search bearings by size also .
Old 02-26-2024, 09:48 PM   #3
FairingWhale   FairingWhale is offline
Any luck on figuring a solution out? I've researched the orion rxb250l supermoto wheels and they seem to be able to fit after pressing new bearings in of the new OD of the wheel and the ID of your axle, along with seals and custom spacers
Old 02-27-2024, 06:49 PM   #4
Bearing swap would be the right way to do it.
Find the CRF230L wheel bearing into here: https://www.partsgiant.com/all-balls
You should be able to find the bearing number and related dimensions.
I'm not certain right now what the axle sizes on the Templar are but you'll needing a bearing with an OD the same size as your hub bearing seat and an ID that matches the Templar axle. Same for the seals.
Went down this road years ago when I did a super moto conversion on a '79 XR500
Old 09-04-2024, 11:39 AM   #5
mark hall   mark hall is offline
is the CRF230 wheel and axle configuration the same as the KPX250?? I gave up on Dual Sport tires.. swapped to stock street tires, WoW!! Going super moto! This KPX is awesome.. power substantially improved from initial.. Got great IDLE torque now.. no clutch slipping in the SloMo..
