11-04-2023, 03:56 AM | #16 | |
If it does, and runs strong at WOT, then it would seem like a needle position thing. Air screw could also need to be set richer. I know airscrew is supposed to be mostly for low end, but mine was way too lean and it was causing problems in the midrange. If you still have bogging at WOT, then maybe the main jet is too rich (or too lean). I don't know how other Hawk owners jet a stock Hawk (jet sizes). Need a Hawk owner to advise here. You are completely stock setup, right?
11-04-2023, 08:40 AM | #17 | |
When I broke into the carburetor I did adjust the fuel mixture screw out half a turn because it did not want to idle out of the box it idles much better now but it could maybe go another quarter to half a turn .I will also try that when I pull the carb off can't hardly get to it while it's on the bike. Thank you Also I got my old smart phone out I'll try and remember to get a picture of the shim and things for you all |
11-04-2023, 08:52 AM | #18 | |
The clip doesn't fit right on my shimmed needle after shimming, because the additional thickness of the washer prevents it from seating in the detent down in the tower. BUT, the big slide spring holds it down once the cable is reinstalled on the slide anyway.
11-04-2023, 12:11 PM | #19 | |
I took the carb off and added a second washer and while I had it off since it's easy to get to I adjusted the fuel mixture screw from one and a half to two turns out. I took it for a quick two block ride and she does not bog out and I got on her pretty good thank you for the help on that |
11-05-2023, 03:24 PM | #20 |
so i have a whooping 29 miles on the hawk now. where to go from here? my thoughts (cheap for now) are
1. exhausts 2. sprockets and chain 3. carb that being said are they worth it? exhausts: https://www.amazon.com/JFG-RACING-Mo...3d670b6bc&th=1 sprocket and chain : i dont know alot about them but i have seen people say oring chains are really good carb : i have heard a lot of good things about nibbi carbs was thinking about this one https://www.amazon.com/Carburetor-PE...3d670b6bc&th=1 what are your guys thoughts and recommendations also what about flat slide carbs are they good? |
11-05-2023, 04:47 PM | #21 |
i have the nibbi kit specifically for the hawk... it works really well and is a breeze to install... i am going to have to fiddle with it as it is kinda bogging down close to WOT... overall the quality is really good
https://www.amazon.com/dp/B0CDVWX9NF |
11-05-2023, 05:18 PM | #22 | |
11-05-2023, 05:24 PM | #23 |
I'm real close to pulling the trigger on that digital dash.
11-05-2023, 05:30 PM | #24 |
yes where can i get one of those. that was another thing i am interested in but that is more on the cosmetic side.
11-05-2023, 05:44 PM | #25 |
11-05-2023, 05:51 PM | #26 | |
11-07-2023, 07:36 PM | #27 |
ok guys i am most likely going to get sprockets and chain this Friday and i need all of your help. this is the thing i am most unsure about
so this is what i have found 17 front https://www.amazon.com/gp/product/B0...MPGW0VRZ8&th=1 45 rear https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1 chain https://www.amazon.com/gp/product/B0...GEBLBY10&psc=1 what are your thought and/ or recommendations |
11-07-2023, 08:14 PM | #28 |
Get a x ring chain. It will be much easier to maintain. The x ring will keep water out of the chain links. https://amzn.to/463mhlA
11-08-2023, 08:43 PM | #29 |
new problem kinda
so i got board tonight and did the air box mod. i filled out the two little tabs and got it all back together. started the bike and and revved it up. now i figured this would change some throttle response and when i snap the throttle fast it will bog and die. if i roll in to it slow its all good. i took it for a ride and rode how i normally do and it rode fine. i dont like that it bogs when in N.
is it the slow jet? do i need to go up one size. thanks |
11-11-2023, 12:48 PM | #30 |
Ordered a new chain and sprockets they should be here on Wednesday. Also go the bike to 108 miles. I am going to change the oil and see how shiny it is lol hopefully not . Haven't got around to switching the slow jet it seems fine while riding but in neutral it bogs when I snap the throttle. I'll probably just get a nibbi next month some time.
I am really happy with is bike. I do want to make it in to a mini adventure bike. Recommendations on good tail and side cases would be appreciated if anyone knows of any |
