Old 09-09-2023, 03:09 AM   #16
KristophDawg   KristophDawg is offline
https://endless-sphere.com/sphere/th...1-of-8.102617/
I found this link
I have a boom bd250-5 superbike that I got from Venom Motorsport
Currently have 6,000 miles
For the longest I hated how the mph was off by 15 to 20 also hated how every other bike was easy to get to settings but not this one haha and here they tell you the code to enter for P0000 to get into settings and other codes
When I found it, i had to try it instantly, tried the code and it works just need to test my bike but had to make an account to let others know
It works
6610 code and I put c as either 1699 or 1700 everything else I leave
Could change 2-004 to 2 and it will make the rpm idle lower
Old 09-09-2023, 03:11 AM   #17
I found this link
Old 09-29-2023, 01:40 PM   #18
gsx95   gsx95 is offline
So I bought the Aliexpress speedometer calibrator in the post above, and it works perfectly on my 21 Vader (it's from Venom Motorsports). This model year has the non-adjustable speedo, but the Aliexpress unit was simple to install and set. I thought my speedo was off by about 20%, so I slowed it by 20% on the calibrator and it was perfect with no further adjustments. For 25 bucks, it's nice to have that fixed.
Old 09-29-2023, 03:54 PM   #19
Originally Posted by gsx95 View Post
So I bought the Aliexpress speedometer calibrator in the post above, and it works perfectly. For 25 bucks, it's nice to have that fixed.
Thank you for coming back and informing us it is indeed the solution we have been looking for.
Old 09-30-2023, 06:04 PM   #20
Actually, thank you for finding and posting it. The speedo error has been bothering me since I got the bike, and I really didn't want to have to rewire another speedo. Now I'm thinking of lowering it more until the actual mileage is correct...
Old 09-30-2023, 08:55 PM   #21
Fast_Freddy   Fast_Freddy is online now
Fast_Freddy's Avatar
Is this speedo calibrator necessary to correct the 22 Templar speedo? Mine reads 3mph fast at 45mph.
22 Templar 250
Old 09-30-2023, 09:36 PM   #22
This will fix any bikes speedometer and any cars speedometer for that matter. Any sensor sending electronic signals to the dash display down a signal wire can be corrected up or down.
Old 10-01-2023, 12:20 PM   #23
Thanks. I was hoping that I could simply change the wheel diameter in the speedo like I do on my ebike.
22 Templar 250
Old 10-01-2023, 01:07 PM   #24
That’s one way to do it and the same speedometer on the Templar that is not the OEM one they’ve custom ordered for the bike will do that. You are simply changing the parameter used in the speed calculation in the dash. When you don’t have access to change that then this is a universal way to fix it. The parameter remains fixed but with this device you are changing the input signal value up or down to force a correction through input signal rather than tire diameter.
Old 10-01-2023, 10:52 PM   #25
So then my options are: new speedo for $28, in-line calibrator for $25 or live with 7% speedo error. I'll live with it for now but it's good to know how to fix it later. Thx.
22 Templar 250
calibrate, speedometer, vader
