#166 |
#167 |
#168 |
#170 |
#171 |
#173 |
#174 |
#175 |
#176 |
#179 |
#180 |
Tesla tows rolling coal larger than itself down the street
2022 1/2 Templar X 250 - 6 gear model - 13 Front / 40 Rear Sprockets - #42 / #120 Jets - 1mm thick nitrile O-ring needle shim (removed) - Kenda K761 Dual Sport Tires - Sedona Standard Thickness Inner Tubes - Stock OEM battery, carburetor, spark plug still going strong - https://youtu.be/dhAYEKH-jFQ Last edited by Texas Pete; 06-25-2023 at 12:53 PM. |
