Old 10-12-2022, 02:43 PM   #1
Richie311   Richie311 is offline
2022 Brozz Recon wont run without choke.
Just got a new 2022 Brozz 250 Recon and it will not start up without choke even when warm. In addition it will not stay running without about a 1/4 choke and dies instantly with no choke. Curious where to start with this and would love some suggestions from you all.
Also when it is on half choke it revs really high.
Old 10-12-2022, 03:02 PM   #2
I would check for intake leaks.
Old 10-12-2022, 04:57 PM   #3
Yeah, intake leaks or one of the passages in the carb is blocked with debris
Old 10-14-2022, 12:06 PM   #4
kyle   kyle is offline
Sounds like intake leak for sure. I had this problem with a cracked plastic between the carb and intake downpipe.
Old 10-14-2022, 12:32 PM   #5
Like everyone said, look for air leaks near the intake, then check thec carb for any blockage.
But most important, don't ride the motorcycle like that.
Old 10-16-2022, 11:22 PM   #6
miraclepieco   miraclepieco is offline
Spray the entire intake system with starting fluid while running. When you hear your RPMs increase, you've found your leak.
