Jetting
Guys I have a odd jetting situation, I went with the Amazon aftermarket exhaust on my TBR7, So I went up from a 110 to a 115 main just, and raised the needle 1 slot, Runs great everywhere but mid throttle, and seems to get worse as she warms, Any ideas where to turn now, I tried a 120 way to rich.
How did it run before the carb changes ?
2021 RPS Hawk "IKEA" (Came in a box with no instructions) 110 main jet 1washer,2.5 sprockets and the cat fell off( with a little help) 1984 Honda V65 Magna "Daddy's Little Monster" To whoever stole my anti-depressants. I Hope Your Happy ! |
It ran pretty close to perfect before the exhaust change, valves are within specs, E3 spark plug, She idles perfect, pulls very well just a mid range stumble that seems to get worse as the bike runs
Maybe increase the pilot jet slightly?
How many turns out is your pilot screw? There is a cap that you need to pry off to access the pilot screw.
Your stock carb has a two piece pilot jet. They are available from AliExpress https://www.chinariders.net/showthread.php?t=30694 Takes a while to get one. If you PM me I can send you one. I would need to know what you have and which one you need (presumably one size higher). Or you can get a new carb that take one piece pilot jets and rejet that one. |
If the issue is mid throttle it is not the pilot jet. Mid throttle, aka between 1/4 and 3/4 throttle is entirely the needle. Lower the needle back down.
Good call Mega. I think our new 2021 TBR7 did benefit from a 38 pilot jet though. The screw was way out. But now it's at 2.5 turns and needs choke for just a half minute or so in these cool Spring mornings. I think it had a 36, so just a minor change (800feet).
Well with the needle in the middle setting the bike runs great, but allways a bit right lots of deceleration popping, and very white plug. But runs great am I over thinking this
The mixture screw it about 2 1/4 turns out
#10 | |
Gentle or aggressive throttle on from mid/low rpm should just invoke torque. If you experience faltering, then it is likely a needle setting issue. If it is happy wide open, then it isn't a main jet issue. 115 main should be pretty close with aftermarket or drilled out exhaust. |
Ok I think I finally found the right combination, 115 main jet, Needle in the bottom slot That seems to be the magic spot here at sea level, Couldn’t make a speed run the Speedo just up and died out of nowhere.
Thankyou everyone for your help
