PARTS PARTS PARTS PARTS
Just add your part (and link to it if you have it) that you know will fit these bikes. I will update the thread here at the top.
Especially looking for parts that are easy to get (ie, from known parts suppliers like JC Whitney or from Honda, Yamaha, Kawasaki, or Suzuki that may be upgrades in quality) Exploded view of parts for OHC version http://roketa.com/product/product_su...=0&proID=25973 http://www.atvforless.com/200gy-parts-web.htm Exploded view of the push rod version Possible parts supply http://www.atvwholesaleoutlet.com/html/parts.html microfiche scans DiamoLM200 : if someone wants to match parts by pics here is a web site you can search for the parts match http://www.daytonafunmachines.com/fiche_select.asp GY-5 Brakes gomoto: Hey guys if you have a gy-5 with rear disk breaks the replacments pads are for a 07 YZF 450. They are a perfect match UNI AIR FILTER POD $13-$15 http://www.rockymountainatv.com/prod...dFamilyId=6800 Rear sprocket bolts/pins katoranger : http://www.chinariders.net/modules.p...ewtopic&t=4173 Walmart Seat Cover katoranger says: I found this info for those wanting a walmart seat cover. A712BLK UPC is 0-4441151143-4 Stearns Comfort Ride ATV Seat Cover PKG-ATV07-0095 Trunk Bag srreynolds2003 says: I found a $24 Trunk Bag This is for a bicycle rack, but it has velcro to hold it on. 13" x 5" x 7" http://www.universalcycles.com/shopp...ls.php?id=8989 Digital Speedo from Walmart for $10 Check out the link http://www.chinariders.net/modules.p...ewtopic&t=1465 EBAY $15 Speedometer/computer. The cool thing is in the features it shows you can set it for maintence reminders, oil change, etc. If the link is broken just go to EBAY and Search "bicycle multifunction speedometer" Voltage LED indicator http://www.customdynamics.com/LED_battery_gauge.htm its a compact, waterproof, indicator, that shows battery state of charge, and of course, charge rate when running. Turn signal bulbs Knothead says: How about some 50 watt turn signals?? Cheaper and brighter than LED bulbs too. http://www.jcwhitney.com/autoparts/P...002844/c-10101 Tail light and License Plate Bulbs madmanjustice says : tail light bulb - EIKO 1157 dropped right in the Rat license plate light - EIKO 194. Both should be easily available at any auto parts store. Replacement KEY RPM says: If you can find a place that has a machine and uses COLE blanks, get them to try a Chrysler "Y107" blank. It worked on the first try for me. Battery Can be found on ebay or other for around $30 including shipping http://search.ebay.com/YTX7A-BS_W0QQ...2dBSQQsbrsrtZd Replacement For: 7A-BS GTX-7A-BS M32X7A 44023 CTX7A-BS YTX7A-BS 25x47x7 dust seals Ericg64 says: Honda OEM 91259-HA7-671 Yamaha OEM 93102-25044 LED Brake Lights PolygonFla says: There are several companies making LED light kits for bikes. Check out the 1157 directfit bulb here. http://www.customdynamics.com/motorcycle_led_bulbs.htm It should just pop right in. Or you could try the one with a pigtail. They also sell prewired boards in verious shapes and sizes. I replaced me taillight on the Zongshen 200 with one I found on e-bay advertized as "A custom Choper LED brake light" Clutch spring upgrade for Roketa (and assumed other 200's) Barnett Clutch parts number 501-56-04015 OR http://www.jcwhitney.com/autoparts/S...&searchbtn.y=7 OR These come 6 to a pack, so if you buy two packs, 3 guys can do this mod for about $7 ea. My Dad has these particular ones in his and they work great. They say 20% stronger than stock on the package. Part number KGS-028 on http://offroad.parts-unlimited.com/21/92/2829483 See thread http://www.chinariders.net/modules.p...ewtopic&t=1103 Clutch lever kens97sto171 says: The number on the package is 30-23032 I think for a 1986-1888 Honda CB 450S according to this googled web site. Not in English http://www.sydfynmc.dk/honda/hondakoblingsgreb.html But on the package is also this number. HON #53178-MF8-000 and this one. 8642817 Scoll down till you see the numbers that match its about 1/2 way down the page. price was $4.92 http://www.leesonsmotors.com/eshoppr...EMENT_CLUT.htm Clutch Cable liverchip says:I found a compatible Honda aftermarket cable that works well. It is listed for use on Bike Bandit for a 2005 CR100 or a mid-70's XR75 according to the bike shop guy. Pro-Motion P/N 02-0163. The cable is about .25 inches shorter but it adjusted out for use on my TMS 200XYi Speedometer Cable (cut to fit) http://www.jcwhitney.com/autoparts/I...D:100000146589 Spokes Known - Lifan and Roketa are interchangable even with rear drum or disk. Assumed to be similar for others, but you need to confirm with pics of the hub. Headlight bulb: BA20D type bulb with 45W http://bulbster.com/lightbulbs/advan...?keyword=ba20d http://www.mopedshop.com/headlight-t...2v4540w20d.htm http://www.denniskirk.com/jsp/produc...d=41101&mmyId= tigertamer says: This is the 35/35 halogen that I am waiting on http://shop.wemoto.com/pictures.dyn?k=HL-770405/10 Here's a halogen, but it appears to be out of stock. http://www.mopedshop.com/Headlight-B...ash-40whal.htm Kawazacky says: 45/40W headlight bulb http://www.consumabulbs.com/files/bdet.php?id=336 tail light bulb zacstewart says: I don't know if Viva's use the same bulbs as Roketas, but the part number is 7528(P21/5W) Sylvania. It's a European bulb. I had to search for it for a while, but it works Mirrors: http://www.jcwhitney.com/autoparts/S...&sku=cag060449 TeamCheap says: I like these mirrors. http://www.denniskirk.com/jsp/produc...d=11508&mmyId= I put a set on my wifes bike and the cool thing is they fold up out of the way via a double ball socket mount that has an adjustable tension.very easy install. They have a less expensive version but were out when I had ordered hers. http://www.denniskirk.com/jsp/produc...d=11508&mmyId= Air filter (K&N cone type): ebay.com (39mm air filter) or (42mm air filter) 4xflyer says... I got the 42mm filter for my pz30 keihin from bikebandit.com Part# VL-61-4810. UNI Multi-Stage Competition Offroad Air Filter http://www.bikebandit.com/partsbandi...id~2106180.asp Tires (Street): Rear--- 120/90-18 http://www.jcwhitney.com/autoparts/I...D:100000209244 A 110 wide rear is recommended. 120 may require minor shimming of the exhaust and toolbox. Front--- 3.00x21 http://www.jcwhitney.com/autoparts/I...D:100000209239 GOOD Prices for tires here with lots of selection. www.americanmototire.com They ship fast and have tubes also. Chain (428H - 126) "Heavy Duty" Count the number of links of your stock chain..this has 126 links. http://www.jcwhitney.com/autoparts/P...Ntt=428h+chain alonzo also says: 130 link moose racing chain "428" Part number, MSE 428 RXP CHN 130 G Front and Rear sprocket replacement or conversion (428/520) http://www.chinariders.net/modules.p...&p=12868#12868 Correct 15 or 17 tooth sprocket for 428 chain http://www.jtsprockets.com/52.0.html...sel_uid=117&p= Spark Plugs. Bold are the suggested plug. NGK- D7EA,D8EA,DR8EA Champion- A8, A6, RA8HC DENSO- X16EP, X16EPR Bosch- ImEasy says his came with a Torch D8RTC plug in it. It cross references to AC - S121*L Champion - A6YC ND - WI6FP-U Bosch - XR5DC NGK Iridium - DR8EIX Denso - IX24 Magnetic Drain Plug Zip Ty Racing. http://www.ziptyracing.com/products/...px?id=MTA1Mw== Dual Star. http://www.dual-star.com/index2/Bran...ain%20Plug.htm Inexpensive Rear Fender Bag http://www.4strokes.com/tech/rearfenderbag.asp Carb jets From Red2003: Sudco has the jets we need here for the PZ27 on the Roketa: http://www.sudco.com/keihin_mj.html#393 We need type 99101-393-xxx, so 2 jets up would be a 99101-393-112 (019-183). Tires (Street/Trail): sheadouglas says - Here's a pretty good sight for new tires. Good prices too. http://www.americanmototire.com/
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
Good list--it should be noted that the chain you listed fits your bike with a 46 t rear sprocket without any modifications needed. I wonder how close it would be for my bike with a 16t front and 44 t rear?
You'll have to count the links on your stock chain. The one I list is 126 links which is a perfect fit for the stock 46 rear.
Jason
Nice job there Fatboy!
word up, not bad for a rocketard!
My name is Justin, my friends call me Stix. 2008 Kawasaki KLR650 Candy Lime Green ______________________________ I am the official China bike registration Guru For the State of Maryland..... HA. |
Hey that's why we're here. These are the voyages of the starship Roketard. Its life long mission: To explore strange new worlds. To seek out new life and new civilizations. To boldly go where no man has gone before!!
i want to do that, but i need a break in the friggin weather so i can get my starship!!! haha...
Suave, when are you getting your mighty china scoot?
i ordered it from TMS last week, i called the shipping company monday and they told me it would be delivered on tuesday, but then they called and told me due to weather, it would be the next day that had decent weather. So probably tommorow or friday?
Its ok tho, i'm just itching to get my hands elbow deep in loctite ![]()
Thanks for your list I am going to save it here on my computer for future use. I agree with you though we should have a spot here to look and find all this stuff. Thanks again Rachel Ride hard and have FUN!!
#11 | |
haha, yea, most def... no matter how cold it is outside, i always have the warm and fuzzy feeling in hooters
![]() the shipping company called me this afternoon and told me it would be here on friday between 12-3.. so i guess i get to take off early friday to enjoy meeting my new bike.
The listed mirrors look nice, they are cheap, has anyone tried them?
#14 |
I actually received a pair of those mirrors yesterday,...
The stock mirrors are too short, and wont tip back enuf to be of any use....... So I ordered the suggested mirrors from JC Whitney......... For the price, they are well worth it.....they are made quite nicely, lots of adjustment, a good height, and the pivot adjustment is very tight...should not have a problem of slipping........look nice, too. Its tips like this that make these online owners forums such a valuable asset.....
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
#15 | |
Jason
