Old 12-10-2021, 07:28 AM   #1
turbofiat124   turbofiat124 is offline
turbofiat124's Avatar
Kymco 90 oil strainer question
Greetings. I haven't been on here in awhile. I bought my daughter a 2007 Kymco 90 Mongoose for Christmas. The same guy who gave me the Tao Tao Brava several years back.
I guess Kymco is considered Chinese. Depending upon if you consider Taiwan a sovereign nation or a runaway Chinese republic...
The guy said the belt was slipping on this thing. After removing the cover I discovered it was leaking oil and had saturated the belt, clutch, etc.
I assumed it was the seal behind the clutch so I replaced it. Cleaned everything up.
While I was at it I decided to do some maintenance on it. On the bottom of the engine there is a screen filter that looks like a thimble. It's hard to get to due to the frame.
I couldn't get it back in. So I left it out for the meantime. I later discovered from this photo that the screen goes inside the spring. It had fallen out when I removed the cap and wasn't sure how it went back in. So that may have been why I was having issues.
Well I go on a test drive and afterwards notice oil gushing from the seal behind the secondary.
Could I have replaced the wrong seal? But the engine was not leaking that much oil before. I found a new seal from a bearing store in town.
QUESTION: Does this strainer act as an oil restrictor? This engine was not leaking that much oil before I removed the strainer. I assumed the oil leakage was the seal behind the clutch.
I'm going to have to lean this bike on it's end to get this thing back in.
I'm curious about this strainer. If it acts as a restrictor and because I removed it, it's pumping way too much oil up into the engine and forcing it out that seal. I'm baffled.
Old 12-10-2021, 07:55 AM   #2
Check that the crank case vent isn't stopped up.
Old 12-10-2021, 11:54 AM   #3
It's an oil strainer. Basically, the oil filter. The oil flows over the outside of the strainer into the engine sump as part of the oil loop. It's best to pull and clean it during an oil change.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 12-10-2021, 12:09 PM   #4
TxTaoRider   TxTaoRider is offline
I cant speak to your specific model, but I've got an arctic cat dvx300, which is a rebrand kymco mongoose, and it's a really well built and trouble free machine. The kymcos are great .
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
