Old 11-22-2021, 10:18 AM   #1
Trupacker   Trupacker is offline
Hawk DLX EFI Stalling
Hello,
I swear I have been trying to find thread with a similar problem, but have not had much luck.
So as the title says I have a 2020 Hawk DLX Fuel Injected bike that keeps stalling. I just bought it with 1,000 miles on it and have only put about an additional 90 on it. It did stall when I first got it, but I just thought it was because it was cold blooded like everyone says and I was not giving it sufficient time to warm up. What is weird is that it only happens when I am riding and let off the throttle. Like when I come to a stop sign or on my way into a turn.
It has a pod filter, so I thought maybe it was running to lean. I have replaced the gas with a higher octane, changed the fuel filter, checked the throttle body, adjusted the idle, ran seafoam through it, and probably a couple things I am forgetting. Besides the pod filter, it is stock. I was thinking of replacing the fuel injector, but I am also having trouble finding the correct replacement.
I am at the end of my mechanical knowledge and have no idea where to go from here. Any help would be appreciated.
Old 11-22-2021, 10:31 AM   #2
They are lean to begin with and im sure the pod filter pushed it past the line. Since there are few options to adjust the ecu easily, i would return to stock if possible.
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 11-22-2021, 10:38 AM   #3
Unfortunately, I do not have the original air box. I will start looking for a replacement. Is it just that the ecu can't adjust for the increased air?
Old 11-22-2021, 10:46 AM   #4
TominMO   TominMO is offline
Essentially, yes.
One thing you could try is to reset the system. Disconnect the two battery leads and hold the + and - wires together for about 30 seconds. This should reset the computer, so that when you fire it up next time it will be able to compensate for the pod filter.
If this doesn't help, you might try wrapping part of the pod filter with duct tape etc, to limit airflow to something similar to how it would be with the factory filter setup.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 11-22-2021, 11:19 AM   #5
Thank you for the replies. I'll give that a try. The pod filter that is on it is kind of large. The one Motocheez suggests is a little smaller. Do you think that might help? Just thinking I might try that if the battery doesn't work. Only $10.
Old 11-23-2021, 01:21 PM   #6
Huck369   Huck369 is offline
Huck369's Avatar
I'll also add, the valves may be a bit tight, as that will cause the stalling also...
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 11-23-2021, 06:31 PM   #7
mototech77   mototech77 is offline
mototech77's Avatar
You may also want to see how the previous owner handled any additional lines that would have gone into the factory air box to be sure you don’t have resulting vacuum leaks, etc. The Lifan EFI bikes seem to have stalling issues even when left stock because of the same lean tune, but adjusting the idle speed up helps with this to a point.
2021 Lifan Xpect EFI
2012 DF250rtc
1982 Yamaha Virago XV750
1982 Honda Twinstar CM200
dlx, efi, stalling
