Old 10-07-2021, 09:22 AM   #1
Jim914   Jim914 is offline
Exclamation New Hawk 250 Wont Shut Off
Does anyone have an idea why my new Hawk 250 wont shut off the engine when I turn off the ignition or hit the kill switch? It just keeps running after I turn it off or hit the kill switch and I stall it out and can still start it with the kick start when the ignition is off. Any help would be appreciated.
Old 10-07-2021, 10:33 AM   #2
braindead0   braindead0 is offline
Suspect bad ground, here's a thread with wiring diagram you can see how the kill and ignition switch interact:
https://www.chinariders.net/showthread.php?t=16065
Old 10-07-2021, 11:22 AM   #3
Emerikol   Emerikol is offline
Definitely a grounding issue. From the way you're describing it, I would guess it's downstream from the ignition switch, and not between the ignition switch and the kill switch. You'll have to check everything out one wire section at a time.
First Rule of Aviation:
-Never Pass Up The Opportunity to Pee
I was struggling to get my wife's attention; I sat down on the couch and looked comfortable. That did the trick!
My wife says I only have two faults. I don't listen and something else...
If at first you don't succeed, try doing it the way I told you to...
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 10-07-2021, 11:47 AM   #4
J4Fun   J4Fun is offline
Because you said your bike is new, any chance the kill switch isn't plugged in or not plugged all the way? This would cause the ground problem. My thoughts!
Old 10-07-2021, 02:15 PM   #5
Found the problem. Thanks for the wiring diagram. It was a wire not plugged into the CDI.
ignition wire, kill switch
