05-27-2020, 01:10 AM | #77 |
The state opened dispersed camping and the nearby OHV areas, so I got to do some camping and riding and test the swing arm out over the weekend.
I'm really pleased with this part. It definitely felt a lot stiffer in the rear (some of that may have been due to the disintegrated rubber in my original swing arm bushing). I'm tall and I really liked the extra ride height also, but I still need to find a new rear shock. The one I tried to order off ebay was sold out. I'll probably do a good adjustable shock now and spacer to get the seat height. Thank you Peace Motorsports for putting this awesome kit together!
http://www.chinariders.net/album.php?albumid=355 |
05-27-2020, 05:07 AM | #78 | |
That added feeling of rigidity isn't entirely all because of your old bushings being shot (though probably a big part of it lol). I noticed the same thing when I went on my first ride. It's a subtle thing, but the rear end just feels a little bit more confident.
10-14-2020, 10:33 AM | #79 |
Ordered the Brozz swingarm kit the other day... I plan to drill a new shock mounting hole below the existing one to try to maintain my ride height, then weld a supporting plate over top of both previous holes just to ensure structural strength.
I also plan to finish welding in the box of the swingarm in front of the adjusters, except for the bottom, as Dan had mentioned in his video overview. I was hoping this would be the last mod and upgrade period... but now Joe Henner has mid to top end focused camshafts available. Oy.. not sure I need one though. Engine pulls strong as it is. |
11-19-2020, 12:47 PM | #80 |
I ordered some stuff from Peace and figured I'd get the swingarm upgrade because i keep finding pics of bent swingarms and frankly I sometimes get some air on the trails.
Anyhoo, my question is shock length. Since my tbr7 already used a short 300mm spring, will it still raise the rear?
12-03-2020, 03:31 AM | #81 |
A little info for tbr7 folks doing the swingarm swap.
Due to the location of the shock mount being higher on the Brozz swingarm it will raise the rear of the bike even with our "short 300mm" shocks. Also, buy the rear brake caliper assembly for the brozz. Then use the Tbr7 master cylinder and connect it to the brozz braided brake line and everything lines up. I think Jeff at Peace sells the entire rear brake assembly for like 45bux. Also, I would like to take a minute and give props to Jeff at Peace, he ships via FedEx right away and I've ordered from him twice and they arrive here in 2 business days. Great place to deal with.
12-03-2020, 06:17 PM | #82 | |
Also, I agree, Jeff is pretty amazing with getting those parts shipped out, and Peace is a great company to work with.
12-06-2020, 06:19 PM | #83 | |
02-14-2021, 05:46 PM | #84 |
the shop.brozz250 site has been showing the swingarm kit not in stock for some time now.
I have been looking at maybe getting an older honda swing arm from flea-bay and modifying to a "pro-link" suspension. any input on the width and diameter of the Hawk/ brozz/ tbr swing arm pivot pont bolt would help to pick a possible donner bike to scavenge parts from. |
02-24-2021, 02:35 PM | #85 | |
Has anyone found a bolt on honda swing arm? |
02-24-2021, 05:08 PM | #86 | |
But there is a thread here , or was it a youtube video. (I'll look). Ant someone added a lowering link. This welded on link is what would be needed to use a honda pro-link swing arm |
06-10-2021, 08:22 AM | #87 |
Can anyone tell me the thread size and length of the two adjuster bolts for the Brozz swing arm?
