03-18-2021, 09:10 PM | #1 |
TT250 Jet Kit install, high idle
Hey all,
I just installed the bigger jet kit in the TT250, but now my idle is rediculously high. Like 12k high. I tried adjusting the idle screw, but it doesn't seem to be dropping the RPMs. I checked the throttle and it seemed ok, but I'm still getting high RPMs. Is it from the kit? Or just some odd user error? |
03-18-2021, 09:27 PM | #2 |
Is your cable seated in it's small bore on the threaded cap on top of the carb?
03-18-2021, 09:31 PM | #3 |
^ this.. if you insert the carb slide in the wrong orientation that will happen.. try unscrewing and then re-orient it to the other side, making sure it slides all the way down before you screw the top back on
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
03-18-2021, 09:35 PM | #4 |
You know a lot more in this area than I do. I was just mentioning what I saw in a MotoCheez video after he jetted a Brozz carb.
03-18-2021, 09:43 PM | #5 |
Banned
+1 on slide being backwards.
03-19-2021, 01:08 AM | #6 |
Thanks for the replies, I'll take a look tomorrow and see what's up with it. It probably was on wrong. I'll update when I figure it out
03-23-2021, 11:17 AM | #7 |
Update and I still need some help
So it was the needle on backwards. I fixed that, but it's now idleing at 4k at full choke. I did modify the airbox to allow more airflow, should I set the needle leaner to drop the RPMs?
03-23-2021, 11:26 AM | #8 |
To rule it out, make sure the throttle adjustment is correct.. it may be holding the throttle slightly open. You can spin the adjuster loose, put in some slack if needed to validate that.
03-23-2021, 11:33 AM | #9 |
Check to make sure the cable is inserted all the way in at the top of the carb.
03-23-2021, 11:39 AM | #10 |
It's also possible the end of the cable isn't seated correctly in the throttle slide.
Also on some of these bikes theres a hose that connects to the intake between the carb and head, make sure that didn't come off (or cap it off if you've removed the smog stuff). It would cause a vacuum leak and high idle.
04-02-2021, 07:20 PM | #11 |
Update: still no fun
I can't tell if the needle in completely. It seems to be as far down as it goes
http://imgur.com/a/7a8jeFC |
04-02-2021, 09:07 PM | #12 |
Your throttle slide is stuck halfway open. That is your problem.
04-02-2021, 09:28 PM | #13 |
Well damn. Thank you. I'll fanaggle with it
04-04-2021, 05:49 PM | #14 |
Update
04-04-2021, 06:55 PM | #15 | |
carbeurator, idle, jet kit, tt250 help |
