Old 02-11-2021, 11:58 AM   #1
DeaselWing   DeaselWing is offline
DeaselWing's Avatar
Engine differences
Hello Folks;
I have a 200CC ZHEJIANG X-MOTOS and I need valves. There appears to be several different types for sale on E-Bay and AliExpress, all with little differences in their specifications, my engine is a ZS169 FMM, where is the best place to get the right valves for it. I have already purchased a set on AliExpress but they are not quite right.
Please advise
Mike Coleman
Ontario, Canada
Old 02-11-2021, 12:36 PM   #2
franque   franque is offline
Send us a picture of the motor, I've got one that's marked ZS169FML, and it's actually a 163FML. Early on there were some, shall we say, "discrepancies" with how they were marked. Also, yours says, based on the FMM part, that it's a Chinese "250", which is marketing speak for 223-229cc. It could also be that it's a Yamaha clone, but we'd need to see pictures.
Old 02-11-2021, 01:35 PM   #3
grumpyunk   grumpyunk is offline
grumpyunk's Avatar
Wouldn't the 169 indicate a 68mm bore, thus making it larger than the 229cc 167's? If so, it is not a 200cc, but closer to a 250?
A ZS167FMM is a Zongshen CG250 engine, essentially. EDITED the model
Displacement is 229cc with a 67mm bore.
x-moto lists valves...
https://www.motor-x.com/zawory-glowicy,c.html
Though it is a long way from Tipperary when you consider shipping.
If you read this post, you may want to measure bore & stroke before ordering anything from anywhere. Seems they will(did) mark them as having a larger bore than was actually the case.
https://www.chinariders.net/showthread.php?t=17552
tom
vertical and above ground - my daily goal
Old 02-11-2021, 03:05 PM   #4
DeaselWing's Avatar
Gents,
It is a 65.5 MM bore, I measured it and calculated the displacement at 230CC if my memory serves me. Franque, I agree on your discrepancies comment. I have been involved with engines, mechanics, motorcycles and engineering for over 60 years and I have never seen anything like this. The bike will be for my grandchildren to ride, so far I have stripped it to the bare frame for cleanup and repaint, changed all the bearings and now it is going back together.
Thanks
Mike
Ontario, Canada
File Type: jpg NOV 11 2020 GIO 250 TRUCK (1) CROPPED.jpg (57.1 KB, 552 views)
Old 02-11-2021, 03:52 PM   #5
Try looking for 165FMM valves. You might be able to get valves for a Hawk or a TBR7 that would work, but out of curiosity, what is the stud spacing on the head?
Old 02-12-2021, 09:27 AM   #6
DeaselWing's Avatar
Franque,
Here is a picture of a head I found on AliExpress, if I cannot find the proper valves I will replace the entire head assembly. I have verified the dimensions shown, this head will fit my bike.
Regards;
Mike
Old 02-12-2021, 11:55 AM   #7
Perfect, I'm glad you found what you needed!
Old 02-12-2021, 03:07 PM   #8
DeaselWing's Avatar
Franque, thank you, stay warm. Winter here, -18C. UGH !
Mike
Ontario, Canada
Old 02-13-2021, 10:58 AM   #9
grumpyunk's Avatar
This listing(I searched for Lifan 200cc valves) may list some that would fit:
https://www.ebay.com/itm/Intake-Exha...wAAOSwd0tdpupl
Down near the bottom, similar sponsored items show dimensions.
tom
Old 02-15-2021, 11:46 AM   #10
DeaselWing's Avatar
Hello Grumpy, thank you, I need a 31.5MM intake, 89.5mm long and a 27MM exhaust, 89.5MM long. 5.5MM stems.
Thanks Again
Mike
Old 02-15-2021, 02:17 PM   #11
grumpyunk's Avatar
Order these, then cut the valve tulip diameter to the narrower dimension you need. Just need a lathe and some machine cutting bits... length is close enough on one you can grind/machine it a bit shorter.
description:
PIT Bike Intake Valve Exhaust Valves fit for Zongshen Loncin Lifan CG250 ATV Go Kart, Moped & Scooter GT-175
https://www.aliexpress.com/item/3280...4%2316062%2387
