125cc won’t fire
Am getting compression, spark and fuel, air mix is correct.
Bike still won’t start up, not even with a bump start. Nor a fully charged after purchasing for 18 hrs at 2amps brand new 12v battery. New plugs. Tried 4 new ones all gapped @0.7mm at spec. Also tried 0.6 and 0.8 New wire loom. New Cdi—Sparks— plus CDai shows timing on a Green LED. Timing chain and cam timing is set correctly. Valves are both .05mm, to tao tao HC stock head specs. Coil does get power to spark plug n from cdi. Kill switch has been bypassed. It has stock starter in it. Stock Starter button switch. Stock horn. Carb has been cleaned every inch has been double checked. New fuel filter n gas gets to carb. Uni Air filter, oiled n ready. Needle clip has been changed to all 5 settings, still no starting, it’s catches for a second, never idles anymore. Not sure what else I’ve not put down but if anyone comes up with ideas shoot em my way please. Anything helps at this point. I did notice exhaust header gasket was not present when I purchased this bike. Just a wider OD piping. Has aftermarket exhaust, clearly showing a leak, also it always popped on de acceleration downhills. Only 4 things to make a engine go boom. Gas air compression spark Compression is good, it pushes against the starter motor when the battery is very low after many attempts of starting it. HELP ME If anyone has any further suggestions feel free to let me know. It’s been a year n the bike still won’t fire up: |
#3 | |
Try adjusting the pilot jet screw, needle position has nothing to do with starting
The pilot jet works in the closed (idle) to 1/4 throttle position. Put you needle clip back on the center position. Turn your pilot jet screw to 1 1/2 turns out. Try to start. Turn the screw in 1/4 turn increments (closed or open) and continue to try to start. You may have to go less than 1 1/2 or out as far as 3. Once it starts, then adjust the idle screw to get an idle in the 2000 rpm range. Then tweak the pilot jet screw up or down and watch the RPM. Your "ideal" pilot jet screw position is 1 1/2, but 2 or so is OK and 1 1/4 is OK. If above 2 1/2, then consider getting a larger Pilot jet. If below 1 1/4, then consider a smaller Pilot jet.
CSC TT250 Orion RXB 150XL |
Where do I go to purchase QUALITY jets?
The engine didn’t have an intake gasket on it: now it does still not firing up.. 94 compression Last edited by Nicthegreat420; 04-06-2021 at 01:34 AM. |
#5 | |
Where to buy jets?
You can get quality no-name ones, or the actual Mikuni or Keihin jets for a bit more. If you aren't sure of what your carb takes (it is a clone of some kind), then take measurements, photos, and your best guess of what it is a clone of (VM, PWK, PE, etc.) and send to Mike. I have always received mine in 2 days. Also buy gaskets, etc. from them.
Carb
Here you go, I’ll find a number in a few hrs.
No pictures shown in your post...
#10 | |
Valves are at 0.005 which is spec. I’ve relighted then over 30 times this year alone n never had the bike running since 2019, around December. For some reason it won’t upload my Photos from any posts.. should I log in via laptop ? Last edited by Nicthegreat420; 09-09-2020 at 05:11 AM. |
#11 | |
Attachment Key Filetype Max Filesize bmp 19.5 KB doc 19.5 KB - - gif 19.5 KB jpe 19.5 KB jpeg 19.5 KB jpg 97.7 KB - - pdf 19.5 KB - - png 19.5 KB psd 9.5 KB - - txt 19.5 KB - - zip 97.7 KB - -
You say it gets spark from the coil is it strong enough? I had coil did not make good contact with the frame because of paint and it would sputter but would not run continuously. You have gas to the carb but is it getting into the combustion chamber. I would be tempted to dribble some gas in the carb and see if it would run awhile, starting fluid can also help but be careful very explosive.
#13 | |
I could sand more on the paint, but I’m getting blue spark on both coils. And old one and a new one. I have tried starting fluid. And fresh gas in tank and new filters ect, and tried dripping fluid into the spark plug hole tool. Still nothing. Got a fresh gasket set in case I do need to tear down one of these two engines, and rebuild what’s worn out. |
#14 |
That looks to be the stock carburetor a PZ25. I would lock the throttle all the way open. Get a spray bottle or dropper some means to get some gas back in the manifold and some gas into it and crank it over. It should run smoothly for a few seconds given you have good spark. If it fired erratically I would think something is off with the timing of the engine mechanically or the cdi signal pickup or cdi. If it ran smoothly for a few seconds I would look at another carburetor to try.
