Old 07-06-2020, 10:04 PM   #1
cheesy   cheesy is online now
cheesy's Avatar
The Diesel Project
Almost four years ago, I scored this Lambordini/Kohler diesel from work. 6.5 hp, electric start, less than 3 hrs on the clock.
The plan was to build a cheap to run motorcycle around it to commute to work on and only get fuel maybe once a month. Well, that fell flat for two reasons. One, I don’t commute anymore. Two, I could not for the life of me find a roller with a title.
Well, half of that has been corrected and the project is back on. Picking up this basket case of a Suzuki GS550 tomorrow morning.
https://chicago.craigslist.org/sox/m...147266998.html
Don’t care about the half an engine, but it has most everything else I need, save for a fuel tank. Most importantly, it has a title.
A lot of other stuff to do before I get to it but watch this space.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 07-07-2020, 07:20 AM   #2
Emerikol   Emerikol is offline
Best of luck with that, Cheesy! I've kind of got an ear to the ground for another frame like that so I can do one of the Harbor Freight engine conversions with a centrifugal clutch setup. I think the missus may be less than pleased if I bring another project home before I have both of the old Hondas up and running. The CB is close; the engine is back in the frame and runs. I just have to route everything back along the frame spine and button it up. Then go get tires and tubes and a few other odds and sods. In any event, please keep us posted with your build. I'm really looking forward to following your progress!
First Rule of Aviation:
-Never Pass Up The Opportunity to Pee
I was struggling to get my wife's attention; I sat down on the couch and looked comfortable. That did the trick!
My wife says I only have two faults. I don't listen and something else...
If at first you don't succeed, try doing it the way I told you to...
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 07-07-2020, 07:37 AM   #3
That right there is what we call in the construction business a project with potential, lots of potential. And potential cost a lot of money. It will be interesting that's for sure. Sub
Old 07-07-2020, 11:37 AM   #4
wheelbender6's Avatar
Cool project. That Suzuki chassis will be more than sturdy enough for that diesel mill.
Old 07-07-2020, 04:25 PM   #5
bogieboy's Avatar
stupid question...LOL what are the plans for driveline? GO kart/snowmobile style torque converter, harley style gearbox, or just straight centrifugal clutch?
Old 07-07-2020, 04:40 PM   #6
It's been done before. You might get some ideas from this video.
Old 07-07-2020, 06:41 PM   #7
cheesy's Avatar
Not a stupid question. First choice is a Harley if I can find a seller that realizes those transmissions are NOT made of gold. Second choice is a torque converter. There are many other bits and bobs I need to scrounge to make this work.
Jerry-Thanks for the video.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-07-2020, 07:30 PM   #8
Bruces   Bruces is offline
Every once in a while I find Harley trannies for less than a few hundred bucks around here Cheese ,how much are you willing to spend on one because I would usually have to grab it quick and ask questions later ?
Old 07-07-2020, 09:40 PM   #9
cheesy's Avatar
Appreciate the offer but I am not in a big hurry for a trans right now. Too much other crap to do. I snagged the Suzuki because I subscribe to ‘He who hesitates is lost’ while Mrs. C is “Good things come to those who wait”.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-07-2020, 10:23 PM   #10
Here are two other videos that are pretty close to what you're planning:
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 07-08-2020, 07:24 AM   #11
cheesy's Avatar
So here’s the haul. Frame w/lower half of engine-trans, fork, two front wheels, one rear, and seat. No tank, lights, gauges, harness, controls, rear brake pedal. A project no matter what.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-08-2020, 09:19 AM   #12
Another tranny that might work is a 3 speed box from a Cushman Eagle, Cheesy.
I don't know if it as rated for power and weight of your project.
Old 07-08-2020, 02:36 PM   #13
franque   franque is offline
You might be able to use the Suzuki bottom end, sans crank for your transmission, it'd just be a bit of welding some aluminum, and connecting the engine to the primary. You could try those aluminum brazing rods that I've seen. It might be easier than you think!
Old 07-08-2020, 04:32 PM   #14
cheesy's Avatar
That is another possibility. Would probably need a jackshaft but won't know until I dig into it. And I do have a TIG welder.
Cheesy
07 Ural Gear Up
79 Honda CX500
73 VeloSolex 3800
Old 07-08-2020, 06:32 PM   #15
Depending on the output/primary side, you might have to run a sprocket to a jackshaft to the other side, but that shouldn't be too hard. IMO it'd make it more interesting!
