06-21-2020, 03:28 PM | #1 |
Bull 200 rear axle ,broken or just shifted loose
Brand new but never used 2 bull 200 atvs ,1 hour of use in 2 years ,took them out this weekend and the axle either loosened or broke ,thoughts on this ,easy fix etc .
06-21-2020, 04:49 PM | #2 |
Jam nuts next to the brake disk came loose. 5 min fix.
06-22-2020, 05:54 PM | #3 |
Not sure what you mean jam but, I called for the part where I bought it and they said it is all one part ,they said it snapped in half .
06-22-2020, 06:49 PM | #4 |
Put a block under the center to raise the wheels. Push in on right hand wheel until the axle splines are inside the sprocket. May have to wiggle the sprocket and disk. Snug up the big nut next to the disk and tighten the other nut against it.
06-22-2020, 06:59 PM | #5 |
The construction seem mirrored albeit otherwise similar to what I have, please read through this link and see if you can draw any wisdom out of it.
http://www.chinariders.net/showthread.php?t=25183
2004 Longjia Grido 50 scooter 1999 Cagiva Mito 125 Evo, Yamaha XV125 engine, Ducati SS fairings, getting turboed 1993 Yamaha GTS 1000 Ex:Bashan BS200-S7 `07 Streetfighter-quad |
