03-01-2020, 12:49 PM | #1 |
Ordered "MIKUNI" VM26 Off of amazon? PICS
So my TBR7 will be here in a few days. I got a head start and ordered this carb off of amazon.https://www.amazon.com/Motorcycle-Carburetor-Go-kart-JetMoto-Motocross/dp/B07V1H6M37/ref=mp_s_a_1_1_sspa?keywords=vm26&qid=1583079781&s r=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzNjVaV jE5NkNFVzU1JmVuY3J5cHRlZElkPUEwNzMwMTQ5TUQyUTQxMjd GTDk4JmVuY3J5cHRlZEFkSWQ9QTA4NDI3ODE2S1Y3UzlCVEtaS FEmd2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRmJmFjdGl vbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
It is definitely different than the clones I have seen. With no markings or stamps on it like the clones I have seen. It came with a 100 main and 42 pilot. A few questions, has anyone else ordered this carb? Does it look like a Mikuni vm26? I ordered a set of main jets for it and planned on using a 110 main or 115 main since I am only 118 feet above sea level. Now I know that a 42 pilot is way rich but I am wondering if it will work for the time being? Probably not right? On to the pics: |
03-01-2020, 06:46 PM | #2 |
Works OK, but pain in the ass to tune
I hope it works out for you, but this is what I have been trying to figure out a replacement for. Don't get me wrong it works OK. It is just a bit of a pain in the ass. I am changing to a VM26-606 with a spigot manifold adaptor. https://tboltusa.com/store/tbparts-m...606-p-742.html
1) You have to remove the carb to adjust the Pilot Fuel screw. So it is off and on and off and on until you get it right. 2) The jets were sort of hard to find...though I did. Even with a photo of the carb Jets R Us was reluctant to give me part #'s. He finally sent me measurements and part #'s and they are the correct ones. This confusuion is mainly because of Mikuni naming two different carbs the same thing "VM26". This one is a 26mm carb (though the tag on yours says 30mm). The VM26-606 is a 30mm carb of a completely different design. 3) The flange mount makes it a chore to remove. Spigot mount is much better. My old fingers don't take well to lining up the 8mm nuts onto the bolts in a tight space! I have gotten pretty good at it, but am used to the ease of a spigot mount. 4) You have to remove the bowl to get to the Main. An access on the bottom of the bowl is much easier. 5) The bowl gasket swells a lot. On mine it was next to impossible to get the gasket back in the groove. I managed to get it close by using a thin screwdriver to push it into place once I had it mostly tightened up. Still ended up with a very small leak. I have ordered 3 more....since the bowl has to come off every time you make a jet change. Figure on a new one every time. They cost $5-$6. Sorry to be a Debbie Downer. Good luck with it.
CSC TT250 Orion RXB 150XL |
03-01-2020, 07:03 PM | #3 |
Tuning Manual
Here is a tuning manual that helped me out. It is not the Mikuni, but the 26mm one is identical. The only thing that didn't make sense was the measurement for the float. I just left mine along.
http://www.ccwthariders.com/uploads/...ing_manual.pdf
03-01-2020, 08:18 PM | #4 | |
Or Ebay has a tool too - I have 1 spare if you can wait |
03-02-2020, 07:03 AM | #5 | |
Sure wish they would have told me that!!
I searched on ebay, amazon, etec. but not using PZ30. I will look right now! Thanks so much.
03-02-2020, 07:21 AM | #6 | |
If this is the "tool" it won't work
https://www.ebay.com/itm/4-stroke-Mo...kAAOSwWktdkF9m It won't work because it is permanent and sticks out too far to be mounted; on my bike anyway. There is not that much clearance under it. (EDIT: I just looked at my bike and this COULD work. Maybe enough clearance. It is cheap enough I am going to try it out) I tried the 90 degree screwdriver in the attached photo, and there is barely enough room to get it into place. Then I can't get it aligned with the screw and turn it at the same time.
CSC TT250 Orion RXB 150XL Last edited by Goob; 03-02-2020 at 07:53 AM. |
03-02-2020, 07:35 AM | #7 | |
If this is it, then it won't work for me....
Maybe a better mechanic or someone with better finger coordination can do this. At my age I have lost a lot of fine finger motion/feel and have a hard time dealing with some of the small stuff. For example, putting the nuts back on the carb manifold bolt on the exhaust side. I came up with a technique where I capture the nut in a closed end wrench and carefully place it in place then use a finger to hold it there while I slowly get the threads to engage by turning the bolt. That is tedious enough....this fuel screw is over the top for me and worth $100 to change the carb out to get rid of the problem. PLEASE let me know if this is the tool you (nzbrakelathes) are referring to or if there is something better. I am open to something better, maybe the fixed set-up that just has a shorter shaft on it.
03-03-2020, 06:54 PM | #8 | |
Orion has them on their website too, $32ish shipped From China $25 total, if you want I have 1 new |
03-03-2020, 10:24 PM | #9 |
Thanks for the info. All this talk about a special tool. I'm pretty sure I could manage to make my own. We will see though. Lol Got my TBR7 today so I'm happy. I'll make a post as soon as I've got all my pics and start my carb work.
03-03-2020, 11:49 PM | #10 | |
Thanks...
I am going to try out the adjustment screw replacement that has a knob on it to adjust. Only $8. If it doesn't fit, then I am scrapping this carb (well, putting it with other parts I have taken off the bike) and buying a VM26-606 with spigot adaptor.
