Old 01-31-2020, 06:02 PM   #46
Landsvw   Landsvw is offline
Landsvw's Avatar
Felt better today and went to work, but done at 12. Came home and worked on the bike. Put gas with sea foam in it. Attached the tank. Finally got it to run on its own! Still won’t idle. But, wired it at 2000 rpms and let it run for 20 minutes. Figured, get some of that sea foam into the carbs, get the engine and carbs up to operating temp and etc. then let it sit and soak and see what happens. Anyway, will report back later if things improve. Has a flat tire and no battery or I’d go drive it too, to help the situation.
1988 Kawasaki KLR250
1969 Honda Z50 silver tag
2002 Ford F-350 7.3 diesel
1975 Corvette
2017 Chevy Bolt
“Throttle twisting geek” -LFN
Old 01-31-2020, 08:46 PM   #47
Landsvw's Avatar
Today
Here she is so far.
File Type: jpg FD47BFCC-3AD8-407F-B09B-B6AE9885A9EE.jpg (20.3 KB, 584 views)
1975 Corvette
2017 Chevy Bolt
Old 02-01-2020, 04:54 PM   #48
Landsvw's Avatar
Anyone close by want to trade for a 1 cylinder 1 carb bike? This thing is making me crazy...
1975 Corvette
2017 Chevy Bolt
Old 02-02-2020, 10:42 AM   #49
Landsvw's Avatar
Helpful link
I have an idea or two and if I feel up to it, will try it today.
1975 Corvette
2017 Chevy Bolt
Old 02-10-2020, 06:40 AM   #50
Landsvw's Avatar
Hahah ok soooo I traded for a KX80...
Has a 100cc cylinder kit on it. Not sure what I’m gonna do with it, but at least ride it a few times then assess...
File Type: jpg 33DD1A07-6740-4D3E-8858-F70A4575871C.jpg (19.5 KB, 599 views)
1975 Corvette
2017 Chevy Bolt
Old 02-10-2020, 10:34 AM   #51
Sport Rider's Avatar
I feel for you with the carb problem. the 4-packs on the kawasaki's can be pretty tough to get clean. Seafoam would not have solved your problem because you likely have some of the small passages blocked. with no treated fuel passing through them, the seafoam would not help. OTOH, the single carb on the other bike will be a piece of cake!
Old 02-15-2020, 11:43 PM   #52
Landsvw's Avatar
Disassembled the KX80 somewhat. Has an older pro circuit pipe and silencer on it. Silencer is very messed up. At first I thought I’d have to get a new one. But, I cut off about 1/2 an inch, got it round again and will weld it back together and to the expansion pipe. Was hose clamped to the frame and a rubber hose connected the two parts. Super bad setup and, the baffles inside were plugged with packing, which I’m sure wasn’t helping it’s ability to run. Haven’t started it yet.
Also learned that as piston size goes up, it doesn’t necessarily mean larger jets. Could mean the same or smaller. Huh. Didn’t know that. But have been doing research. Will examine jet sizes, repack and seal the exhaust and see how it goes, hopefully in the next few days.
1975 Corvette
2017 Chevy Bolt
Old 02-16-2020, 07:13 AM   #53
cheesy   cheesy is offline
cheesy's Avatar
A cheap HF ultrasonic cleaner probably would have helped clean the Zuk carbs, but yeah, four carbs is two too many.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 02-16-2020, 08:10 PM   #54
I've found two strokes to be a fickle mistress when it comes to mods. It'll be interesting to see which jets work best for you. I find them to particularly sensitive to float level.
Old 02-21-2020, 11:47 PM   #55
Landsvw's Avatar
Got the air filter installed, carb cleaned and muffler welded and painted. Still have to pack it and reinstall it.
1975 Corvette
2017 Chevy Bolt
Old 02-23-2020, 11:54 PM   #56
Landsvw's Avatar
Ok! Got the KX80 running and ripping! Sure is fast and loud.
File Type: jpg A6542D0E-CACA-4AD5-BB42-4B9C1B01D035.jpg (20.1 KB, 545 views)
File Type: jpg 03C50F5F-5778-458F-B34F-07DC31121E65.jpg (19.7 KB, 540 views)
1975 Corvette
2017 Chevy Bolt
Old 02-26-2020, 09:39 AM   #57
Landsvw's Avatar
Rode it then sold it! Made a little profit of 800$. Trying to pay for my latest acquisition: 2002 Ford F-350 super crew dually 7.3 diesel.
Wife and I decided that our 2001 F150 wasn’t cutting it towing the 5th wheel so we upgraded somewhat. Super crew F150 is now for sale too.
File Type: jpg 31E1F2AB-34EF-45B1-84BB-A4433CDFE022.jpg (9.4 KB, 521 views)
File Type: jpg 2B8A1C8B-9DBF-44E3-A30C-F8CA0B4792BA.jpg (20.0 KB, 533 views)
1975 Corvette
2017 Chevy Bolt
Old 02-29-2020, 01:37 AM   #58
Landsvw's Avatar
The F150 sold today, and so now, on to the reviving of the F350! Mostly interior work like torn seats and super dirty... gotta install 5th wheel rails too.
1975 Corvette
2017 Chevy Bolt
Old 03-02-2020, 08:09 AM   #59
Landsvw's Avatar
Repairs done Saturday and Sunday
Turn signal switch
Window and radio hack (delay wasn’t allowing them to work)
Remove extraneous wiring
Cleaned interior (partially, like 1/4 so far)
Fix and clean dash, and reinstall radio
Oil and filter change
Air filter change
Add antifreeze stabilizing (ph balance)
1975 Corvette
2017 Chevy Bolt
Old 03-03-2020, 11:35 AM   #60
That F350 deserves a thread of its own.
