So I feel like I might have screwed something up.
Today I was attempting to change out my sprockets, failed and ended up having to put in my original sprockets back in (tipped over my bike in the process and took off the tip of the brake lever ![]() When I put everything back together, I realized that my bike was really hard to push around in neutral and I would hear a clicking or ticking sound as well. Did I over tighten my axle nut? Any ideas would be appreciated for this utter newbie. |
Brake is being held on?? When you broke n bent front brake lever
Is your chain too tight?
#4 | |
The chain tension and alignment being incorrect will also cause binding which can then cause drag and make the bike hard to move. It may also be the source of the clicking sound you are hearing.
Thank you guys for the suggestions!
I realized my chain was way too tight and that was the cause of the difficulty rolling. Unfortunately I have come across a new problem. The piece of metal connected to the rear brake caliper has cracked due to my use of excessive force in torquing the rear axle nut. The weird thing is that my front brake is also having issues now. I'm posting some pictures to give you guys an idea of what's going on. https://imgur.com/a/ZOraNhh |
You miss aligned the groove that stops it rotating - you’ll need a new bracket
Gotcha. Where can I buy a new bracket? Is it possible to JB weld it together?
I tend to be on the thrifty/cheap side when at all possible but my gut says to replace that bracket. If there’s one place to not cut corners it’s your brakes. No telling when (or how hard) you will need them.
#9 | |
Thats a very easy "I second" ...replace it with a new part...no JB Weld there
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
#12 | |
#13 |
I agree with that assessment. It is possible that too much compressive force could crack that bit of metal, but it is more likely it cracked due to impact,
#14 |
I would check with the dealer you bought it from. Also the bracket from the TT250 might be an alternative. https://store.cscmotorcycles.com/TT2...p/zt23-101.htm
#15 |
That's unfortunate. I went to the dealer where I bought the bike and they told me they didn't have any of the brackets in stock so it looks like I'll need to buy the TT250 one that you've mentioned JerryHawk. Thanks for the suggestion!
