02-04-2007, 08:14 PM | #16 | |
06 Roketa RSX 200E (DB 07A) |
02-06-2007, 09:59 AM | #17 |
Hey Guys
There is an adjustment rod below the rear master cylinder with a lock nut on it that goes to the rear brake arm. You need to adjust more free play in the arm to stop them from locking up. I hope that this helps. Bruce
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
02-06-2007, 11:32 PM | #18 |
Hey Bruce
I appreciate the help! do you mean to loosen that jam nut to allow some movement I ve seen the rod you are refering to. should it be adjusted out longer. there is also a stop bolt to control the height of the pedal. ahh heck Ill just turn some stuff and see what happens LOL Thanks Ray
